Page 1 of 2
BHP - Torque
Posted: Tue Mar 25, 2008 1:23 pm
by musty1
How do convert your BHP to Torque??
RE: BHP - Torque
Posted: Tue Mar 25, 2008 1:29 pm
by Blue_Thunder
Smaller heads? Higher compression ratio?
RE: BHP - Torque
Posted: Tue Mar 25, 2008 2:02 pm
by musty1
sorry I mean figures ie if i have 300 bhp car how do work out the torque
RE: BHP - Torque
Posted: Tue Mar 25, 2008 2:41 pm
by dummi
(power x 5252)/ revs = torque
Posted: Tue Mar 25, 2008 2:44 pm
by musty1
cheers :thumbs:
Posted: Tue Mar 25, 2008 2:49 pm
by musty1
the rev is that limit of revs ie 300x5252/7200=218 is that right??
Posted: Tue Mar 25, 2008 3:22 pm
by S4TAN
That's for torque measured in Nm isn't it? Or is it lbf.ft ... ?
Posted: Tue Mar 25, 2008 3:30 pm
by dummi
rev's is the point at which you are making max power which will be toward the redline unless u r on k03's lol
in lbft
Posted: Tue Mar 25, 2008 3:46 pm
by S4TAN
This is good stuff - I've just stacked up the formula against my last RR results; works well, the maths is almost a perfect match for the power and torque curves as plotted against RPM.
Incidentally it shows my power and torque tail off quite steeply beyond 5,500rpm .... I think that must be my optimal point in the rev range to change up a gear .... (but the cooling/air supply was pretty pants on the RR for that session and the car was suffering major heatsoak, so maybe on the "real road" it could be further up the rev range .... maybe 6,000rpm??)
Posted: Tue Mar 25, 2008 3:47 pm
by musty1
so if i was to say 300x5252/4800(full boost)=328 right?
Posted: Tue Mar 25, 2008 3:53 pm
by bobbler
My stats are in my sig, so think the resulting value is a ft/lbs?
Posted: Tue Mar 25, 2008 3:56 pm
by S4TAN
Yeah - definitely lbf.ft
Posted: Tue Mar 25, 2008 3:59 pm
by S4TAN
musty1 wrote:so if i was to say 300x5252/4800(full boost)=328 right?
Yes - if you're making 300hp at 4800rpm. Have you got a dyno plot?
Posted: Tue Mar 25, 2008 4:00 pm
by musty1
482nm=355 lbf.ft not bad
Posted: Tue Mar 25, 2008 4:01 pm
by musty1
for those that have not draged there car this is a calculator estimating your results
http://www.letstorquebhp.com/calculator.asp
