Mixing your (car's) drinks
Posted: Thu Aug 02, 2007 10:49 am
Is there any rule of thumb around which weight you use when topping up your oil?
So long as you are running fully synthetic, would it cause problems say if you had 10W60 at the oil change, but topped it up with 10W40?
I know ideally you would probably want to use the same, but would it cause any issues mixing different weights?
