Audi A6 2.5TDI very bad white smoke from rear?
Posted: Wed Aug 30, 2006 12:42 pm
by abc5k
Hi
Can anyone help? Pure white smoke coming out of A6 2.5 TDI rear Pipes year 99, have checked head its ok have checked all cylinder compression and that ok to it is burning a lot of oil , can anyone help me in this situation? thanks Ash
RE: Audi A6 2.5TDI very bad white smoke from rear?
Posted: Wed Aug 30, 2006 2:14 pm
by grizz
ash , it could be the the turbo!
Posted: Wed Aug 30, 2006 2:59 pm
by philipwalker
As Grizz suggests it could be the turbo the problem, is more noticable on idle?
Pull the hose from the airbox to the turbo off and check the movement in the turbo, should only be a slight side movment.
Other known problems with this engine are often caused by a blocked crankcase breather. It is located in the V of the engine to the rear of the fuel pump. The crank case pressure builds causing oil to be forced out from the turbo seals. This is obvious when removing the oil cap. There is a test that the dealers perform using a pressure tester in the dipstick hole.
white smoke
Posted: Wed Aug 30, 2006 8:46 pm
by abc5k
thanks Phillip , you are correct thats whats wrong with it . thank you very much !
