How Do I Get To The Bulb?
Posted: Tue Mar 07, 2006 4:56 pm
by claytow
Hi guys,
Have a failed rear fog light and want to replace it but cant really see how to get at it. Take it that you take off the inner boot lid lining, but cant see how to do that either and dont want to pull it too much in case I rip it.
Any help appreciated. Thanks
RE: How Do I Get To The Bulb?
Posted: Tue Mar 07, 2006 9:24 pm
by johneroberts
Is this a RS4?
you dont say
but its easy if it is
jr
Posted: Wed Mar 08, 2006 7:05 am
by claytow
Oops my apologies, no its a W reg 2000 S6.
Posted: Wed Mar 08, 2006 11:43 am
by johneroberts
No idea im affraid!
jr
Posted: Fri Mar 10, 2006 6:08 pm
by claytow
Problem solved. There is only one working Fog light on a S6. They dont wire up the other one.. go figure !
Posted: Mon Mar 13, 2006 12:18 pm
by peterb
Audi have only equipped one rear fog light for as long as I can remember - I think the idea is that if there's only one, it's much less likely to get confused with brake lights.
However, on the C5 range, in particular, the fog lights are so far inboard that I can't see a problem with both being operative.
Posted: Mon Mar 13, 2006 1:43 pm
by tartan_rob
My 1998 S4 has two fog lights that both work. One in each cluster. The wiring is there but the circuit board needs a little bit taken out in order for the bulb to be inserted.
Posted: Tue Mar 14, 2006 1:21 pm
by peterb
Similar on my 96 A4 Avant. Everything was wired up, so I just inserted a bulb - it was than that I found that the bulb holder wouldn't go back in the lamp housing. I had to remove a small blanking piece from the lamp housing.
