NEW MEMEBER-ONE QUESTION ABOUT OIL
Posted: Thu Jan 12, 2006 2:35 pm
by ifcjti
Hi, just signed up for this wonderful site. I own a 1995 S6 with 90k miles. I was wondering about switching to synthetic oil. I know it has probably been discussed many times on this forum. Would someone mind giving me some good advice on making this decision. Next oil change in 1500 miles, thinking of switching to Mobil 1, would this be wise? I appreciate your insight, thanks
RE: NEW MEMEBER-ONE QUESTION ABOUT OIL
Posted: Thu Jan 12, 2006 2:43 pm
by Dippy
Welcome. Yes oil is often discussed, but not your particular question. IIRC your S6 has an NA engine so is not as sensitive as the turbo engines. I think using synthetic will be of marginal value to you, perhaps just to last longer between changes.
Maybe someone more experienced with these engines will offer better advice.
Re: RE: NEW MEMEBER-ONE QUESTION ABOUT OIL
Posted: Fri Jan 13, 2006 10:04 am
by peterb
Dippy wrote:IIRC your S6 has an NA engine so is not as sensitive as the turbo engines.
I'm fairly certain the S6 has the 2.2 I5 turbo engine.
RE: Re: RE: NEW MEMEBER-ONE QUESTION ABOUT OIL
Posted: Fri Jan 13, 2006 2:21 pm
by ifcjti
Yes, my S6 has the 2.3 turbo engine. So, what does this mean as far as switching to synthetic oil now that I have reached 90k miles? Thanks
Posted: Mon Jan 16, 2006 11:31 pm
by oilman
Use a quality synthetic oil if the car is turbocharged as they dissapate heat better.
Something like a 5w-40 or 0w-40 would be my recommendation.
Simon
Posted: Tue Jan 17, 2006 11:28 am
by Greg_S
ow-40 is too lower viscosity to use really. Millers RS10W/60 works a treat
Posted: Tue Jan 17, 2006 11:37 am
by oilman
It's not actually, sae 60 is too thick. You need an sae 40.
0w-40, 5w-40, 10w-40 as recommended in your handbook.
Simon
Posted: Wed Jan 18, 2006 10:04 am
by Greg_S
the reason I say that is a 0w-40 thins out and gets too hot on the track. Currently im using 5w-40 fully synth
Posted: Wed Feb 01, 2006 2:16 pm
by oilman
It shouldn't do unless it has thinned further with use.
0w-40, 5w-40, 10w-40 and 15w-40 are all the same thickness (14cst) at 100degC.
Centistokes (cst) is the measure of a fluid's resistance to flow (viscosity). It is calculated in terms of the time required for a standard quantity of fluid at a certain temperature to flow through a standard orifice. The higher the value, the more viscous the fluid.
As viscosity varies with temperature, the value is meaningless unless accompanied by the temperature at which it is measured. In the case of oils, viscosity is generally reported in centistokes (cst) and usually measured at 40degC and 100degC.
So, all oils that end in 40 (sae 40) are around 14cst thickness at 100degC.
This applies to all oils that end in the same number, all oils that end in 50 (sae 50) are around 18.5cst at 100degC and all oils that end in 60 (sae 60) are around 24cst at 100degC.
With me so far?
Great!
Now, ALL oils are thicker when cold. Confused? It's true and here is a table to illustrate this.
SAE 40 (straight 40)
Temp degC.........................Viscosity (thickness)
0..........................................2579cst
20..........................................473cst
40..........................................135cst
60..........................................52.2cs t
100........................................ 14cst
120.........................................8.8cst
As you will see, there is penty of viscosity at 0degC, in fact many times more than at 100degC and this is the problem especially in cold weather, can the oil flow quick enough to protect vital engine parts at start up. Not really!
So, given that an sae 40 is 14cst at 100degC which is adequate viscosity to protect the engine, and much thicker when cold, how can a 0w oil be too thin?
Well, it can't is the truth.
The clever part (thanks to synthetics) is that thin base oils can be used so that start up viscosity (on say a 5w-40 at 0degC) is reduced to around 800cst and this obviously gives much better flow than a monograde sae 40 (2579cst as quoted above).
So, how does this happen, well as explained at the beginning, it's all about temperature, yes a thin base oil is still thicker when cold than at 100degC but the clever stuff (due to synthetics again) is that the chemists are able to build these oils out of molecules that do not thin to less than 14cst at 100degC!
What are the parameters for our recommendations?
Well, we always talk about good cold start protection, by this we mean flow so a 5w will flow better than a 10w and so on. This is why we recommend 5w or 10w as the thickest you want to use except in exceptional circumstances. Flow is critical to protect the engine from wear!
We also talk about oil temps, mods and what the car is used for. This is related to the second number xw-(XX) as there may be issues with oil temperatures causing the oil to be too thin and therefore the possibility of metal to metal contact.
This is difficult to explain but, if for example your oil temp does not exceed 120degC at any time then a good "shear stable" sae 40 is perfectly capable of giving protection.
"Shear stability" is important here because if the oil shears it thins and that's not good!
However, if you are seeing temperatures in excess of 120degC due to mods and track use etc then there is a strong argument to using an sae 50 as it will have more viscosity at these excessive temperatures.
There are trade offs here. Thicker oils cause more friction and therefore more heat and they waste power and affect fuel consumption so it's always best to use the thinnest oil (i.e. second number) that you can get away with and still maintain oil pressure.
There is more but this post is too long already so lets keep it to basics.
Simon
Posted: Wed Feb 01, 2006 3:08 pm
by Paulm
excellent post as always Simon.
Paul
