removing numberplate
Posted: Fri Feb 11, 2005 11:20 am
by mikhailk
how do you remove a british numberplate without ripping the paint off or damaging the car? i think its glued on or something.
any advice very welcome
RE: removing numberplate
Posted: Fri Feb 11, 2005 11:36 am
by simple1
Most plates are installed by the use of double sided tape........... if you pull gently, you should not damage the paint.
Posted: Fri Feb 11, 2005 7:00 pm
by PhilT
A hair dryer helps to soften the glue.
Posted: Fri Feb 11, 2005 8:25 pm
by mikhailk
thanks for the advice. so i tried to slowly force the number plate off at one edge, and it gives, but i can see that the yellowish stuff that makes the number plate, it kind of wants to stay down, and it is just coming off the transparent bit of the plate.
i dont think i can get a hairdryer down to my car here, shall i try sticking a knife blade between the car and the plate?
Posted: Sun Feb 13, 2005 6:58 pm
by teknobod
Definitely don't use the knife.
If you can't get a hair dryer to the car, I've used dental floss before now pulled to and fro behind the plate.
Andy
Posted: Mon Feb 14, 2005 2:17 pm
by alastairg
Dental floss everytime. Brand does not seem to influence performance
Posted: Mon Feb 14, 2005 11:20 pm
by PhilT
If you need to remove the adhesive try cooking oil.
Posted: Tue Feb 15, 2005 7:54 am
by simple1
That sounds like you are revealing more of your bedroom secrets Phil
