2.0 TFSI B7
Posted: Tue Jun 07, 2016 7:44 am
by boombastik
can someone help me identify the PCV crank case breather on the 2.0 TFSI engine apologies this isn't RS related
my friends car and when I open the oil cap the engine is in vacuum so ross tech suggests that the crank case breather is fooked
Re: 2.0 TFSI B7
Posted: Tue Jun 07, 2016 8:01 am
by pule333
Do you see that ally metal plate with two black pipes? That's where the OEM pcv valve is.
By the way this kit I have is for sale if you friend wants to eliminate this problem once and for all ;)
Re: 2.0 TFSI B7
Posted: Tue Jun 07, 2016 8:09 am
by boombastik
cheers
so guessing stock item is this https://c1552172.ssl.cf0.rackcdn.com/346248_x800.jpg
Re: 2.0 TFSI B7
Posted: Tue Jun 07, 2016 8:10 am
by pule333
Yes
Re: 2.0 TFSI B7
Posted: Tue Jun 07, 2016 8:11 am
by boombastik
perfect cheers
Re: 2.0 TFSI B7
Posted: Tue Jun 07, 2016 6:23 pm
by TobyRS4
I'd recommend the external oil catch tank type like pictured, had the same issue on a mk5 golf gti 2.0 tfsi and fitted a catch tank as above which cured the problem
Re: 2.0 TFSI B7
Posted: Tue Jun 07, 2016 6:34 pm
by boombastik
TobyRS4 wrote:I'd recommend the external oil catch tank type like pictured, had the same issue on a mk5 golf gti 2.0 tfsi and fitted a catch tank as above which cured the problem
Don't think she's that bothered as long as it fixes the issue.
Re: 2.0 TFSI B7
by pule333
Like I said, pm me if interested.
