Brake upgrades
Posted: Wed Jan 06, 2016 11:08 am
by Vari Perf Brakes
Hi Folks
We are back up and running after the Xmas break and are taking orders for brake kits , please see our FB page or website
for more details we hope to be able to help with your braking needs .
Re: Brake upgrades
Posted: Wed Jan 06, 2016 1:09 pm
by bam_bam
Interesting!
FON.
I'll do rule 1 for you.
Re: Brake upgrades
Posted: Wed Jan 06, 2016 1:17 pm
by John Johnson
How much are they then as there's nowt on your website ?
Re: Brake upgrades
Posted: Thu Jan 07, 2016 12:01 pm
by Vari Perf Brakes
John Johnson wrote:How much are they then as there's nowt on your website ?
Front discs to fit std bells £550.00 per pair Rear on aluminium bells £510.00 per set .
Re: Brake upgrades
Posted: Thu Jan 07, 2016 12:32 pm
by bam_bam
...fronts on custom bells? For example, a good disc mated to a custom aluminium bell to fit an RS6 (C5 or C6 - both have different ET).
Re: Brake upgrades
Posted: Thu Jan 07, 2016 2:01 pm
by C_J
Do you do other designs to the discs? I.E drilled? Just not a massive fan of the gone wrong Nike swoosh. :|
Re: Brake upgrades
Posted: Thu Jan 07, 2016 2:04 pm
by chunky79
You have the possibility of drilled discs cracking.
Re: Brake upgrades
Posted: Thu Jan 07, 2016 2:32 pm
by Vari Perf Brakes
C_J wrote:Do you do other designs to the discs? I.E drilled? Just not a massive fan of the gone wrong Nike swoosh. :|
We avoid drilled discs as they are prone to surface cracking around the holes which some people see as a major issue but generally do not cause any problems .
Re: Brake upgrades
Posted: Fri Jan 08, 2016 2:19 pm
by Vari Perf Brakes
Hi we do a378mm disc that we could fit to your std bells they go for £570.00 per set ,I will check if we can do custom bells ,
This should not be an issue .
Re: Brake upgrades
Posted: Fri Jan 08, 2016 2:26 pm
by bam_bam
Where are you lot based?
Re: Brake upgrades
Posted: Sun Jan 10, 2016 3:31 pm
by Vari Perf Brakes
bam_bam wrote:Where are you lot based?
Based in Bicester but let me know what you are looking for as most parts are done to order at the moment .
