battery conditioner.
Posted: Sun Mar 08, 2015 7:58 pm
by rocket1
hi all, can anyone recommend a battery conditioner /trickle charger i can leave connected in between use on my rs4. recently got power to my garage and can now get something plugged in when i,m not using it!
thanks folks!!
Re: battery conditioner.
Posted: Sun Mar 08, 2015 8:19 pm
by Ian_C
CTEK! :thumbs:
Posted: Sun Mar 08, 2015 9:06 pm
by MikeFish
I use the Optimate 4 after all the recommendations it had on here:
http://www.optimate.co.uk/optimate%204%20dual.htm
Posted: Sun Mar 08, 2015 9:16 pm
by marc1
Posted: Mon Mar 09, 2015 11:59 am
by miatang
Ian_C wrote:CTEK! :thumbs:
I'm one for Ctek aswell. Used it for years on various vehicles without a single problem
Posted: Mon Mar 09, 2015 1:49 pm
by rocket1
thanks lads. will look into a ctek as suggested. mike ive used optimates on my bikes but thought the ah of the car battery was too much for it.
Posted: Sat Mar 21, 2015 3:12 pm
by RossDagley
rocket1 wrote:thanks lads. will look into a ctek as suggested. mike ive used optimates on my bikes but thought the ah of the car battery was too much for it.
I've used the optimate for years. Excellent conditioner and trickle charger :) Worked fine on the RS4 when I had it :)
Posted: Tue Mar 24, 2015 5:29 pm
by Graeme4130
I used an Accumate for years on an old tvr I used to garage over the winter ;
Quite cheap, but does everything you need, and you can get a cigarette lighter charger for it, so you charge the car through the lighter socket
http://www.accumate.co.uk/accumate.htm
Posted: Tue Mar 24, 2015 7:02 pm
by marc1
Graeme4130 wrote:I used an Accumate for years on an old tvr I used to garage over the winter ;
Graeme, you mean you run it without trailing wires to an external socket and all the wiring can then be contained within the car itself? If so, that's gla great product.
Posted: Tue Mar 24, 2015 8:46 pm
by Graeme4130
haha, yeah, it'd be amazing if the battery charges the battery :)
I always found connecting the charger into the battery terminals a pain in the arse if you just want to get in and go and then park it back up, so having the car end of the charger plug into the cigarette lighter is an easy solution
I assume the Audi electrics will allow it to charge the battery through the Lighter port as the TVR was very simply wired, but Audi's tend to be a bit more complex ?
This is the part ; http://www.accumate.co.uk/o-12.htm
