2012 audi rs4 front brake pads ceramic
Posted: Thu Jan 01, 2015 7:54 pm
by Aungkhin
Hello people I have recently brought a 2012 audi rs4 the brake pad light had come up on the instrument cluster and I took a look and the front ones are really low, I have browsed the Internet for some pads but can't find any anywhere Iv called tps etc and they only do non ceramic brake pads so I presume its dealer only does anyone have any idea what sort of price these brake pads are and where I can get them from apart from audi thx for your help in advance
Re: 2012 audi rs4 front brake pads ceramic
Posted: Thu Jan 01, 2015 10:17 pm
by Revolution
Search for littledevils on here as he sticks them..
Posted: Fri Jan 02, 2015 1:00 am
by Surrey Sam
This thread makes no sense really, other than the OP needs new pads.
Do you have a Steel setup or a Ceramic one; what colour are your brake calipers, Grey or Black?
Posted: Fri Jan 02, 2015 11:03 am
by Aungkhin
Calipers are grey
Posted: Fri Jan 02, 2015 4:13 pm
by Surrey Sam
Unfortunately Ceramic discs use a different type of pad compound to work together and that means less choice.
Stoke Audi will do a set for around £310, whilst the only after market solution I've heard that works with Porsche's ceramic discs is the Pagid RS29 brake pad. I'm yet to hear any Audi ceramic disc users utilise a pad other than the OEM one though.
If you don't mind me asking, how many miles have you covered on those pads?
Posted: Fri Jan 02, 2015 5:34 pm
by Aungkhin
Car has just covered 25,000 miles and didn't think they would be cheap rear pads are £85 from solihull audi which isn't too bad but front was quated £350 and wear sensors £59 a side!!
Posted: Fri Jan 02, 2015 11:25 pm
by Graeme4130
Aungkhin wrote:Car has just covered 25,000 miles and didn't think they would be cheap rear pads are £85 from solihull audi which isn't too bad but front was quated £350 and wear sensors £59 a side!!
That's quite early to be replacing ceramic pads ?
Rears are steel, and nice and small, so pretty cheap in comparison
Due to the ridiculously huge cost of replacing the ceramic disc, I'd be very reluctant to use anything other than OEM pads fitted anywhere other than a dealer
Posted: Sat Jan 03, 2015 2:09 pm
by Surrey Sam
As above.
I shall be replacing mine with Audi ones, not worth the risk and the OEM performance is great anyway.
Posted: Sat Jan 03, 2015 2:27 pm
by Graeme4130
Surrey Sam wrote:As above.
What's the miles on your pads Sam ?
Posted: Sat Jan 03, 2015 3:11 pm
by Surrey Sam
Graeme4130 wrote:Surrey Sam wrote:As above.
I don't honestly know Graeme, as my Ceramics came off another car I purchased which had done 60k. I could find no record of a pad change when investigating its history and they appeared to be around 2/3rds worn?
Just can't believe the setup would have done over 60k on a single set of pads, although the pad backing plates were breaking out in rust and looked to be that sort of age. I want to get them replaced mainly because I don't want to risk getting down to the backing plate pins and ruining the disc face - like you can get with the steel B7 setup.
Previously, I've googled
(is that a word now?) Porsche PCCB pad life and read experiences of great pad life. There just isn't any Audi experience out there that I could find.
Posted: Sat Jan 03, 2015 3:26 pm
by Graeme4130
My understanding is to expect 60-80 from the pads and 120+ from the discs
Porsche discs and pads are now the same material and design as Audi RS products, so life expectancy should be similar I'd hope (although you might argue that typically, porsche's get a harder life if someone's had the foresight to order ceramics
Posted: Sat Jan 03, 2015 4:22 pm
by geordie jay
wow sam I didn't realise you were using ceramics fella.
Posted: Sat Jan 03, 2015 7:33 pm
by Surrey Sam
geordie jay wrote:wow sam I didn't realise you were using ceramics fella.
Yeah, had them for about 4 months now Jay.
Just 4 more options to go before I have every one in the brochure except the exclusive paint/interior, two of which I don't want anyway. I'm such a spec whore
Graeme4130 wrote:My understanding is to expect 60-80 from the pads and 120+ from the discs
Yes, so glad Audi didn't have the same issue as the PCCB's had to begin with - it could have killed all faith in Ceramic brakes. OK, 60-80k that's quite a bit, if mine are original then they're on the money.
Posted: Sat Jan 03, 2015 8:17 pm
by geordie jay
Surrey Sam wrote:geordie jay wrote:wow sam I didn't realise you were using ceramics fella.
and a bitch don't forget that
