HELP WET REAR PASSENGER FLOOR ON ME RS6
Posted: Sat Nov 22, 2014 3:20 pm
by brassy1975
HI JUST CHECKING ME NEW CAR OUT WHEN IV DISCOVERED THE REAR PASSENGER FLOOR REALLY SOAKING LIKE SOME ONE HAS POURED WATER ON IT , CHECKED ALL THE SEALS AND THEY LOOK FINE COULD IT BE OOT ELSE LIKE AIR CON OR SOMETHING ??????
Re: HELP WET REAR PASSENGER FLOOR ON ME RS6
Posted: Mon Nov 24, 2014 12:11 am
by bam_bam
Stop shouting! Turn off your cap-lock.
Your drain is probably blocked under the scuttle or you've parked on a hill. The water comes in at the pollen filter and takes the lowest path to the rear near-side.
Pull out the scuttle and clean out your drains.
Posted: Mon Nov 24, 2014 11:46 pm
by brassy1975
checked under the front carpet and thats soaking to , is the best think to take all the carpet out and dry it properly because it'll not dry properly if i dont will it , sorry am a clueless git when it come s to cars
Posted: Tue Nov 25, 2014 2:04 pm
by bam_bam
Dry 'em however you can. I used a heatgun on low, it took an age.
Posted: Tue Nov 25, 2014 11:57 pm
by brassy1975
TAKEN IT TO ME MATES PAL WHO DEALS WITH AUDIS , HE S GOING TO TAKE THE SEAT OUT AND THE CARPETS AND HANG THE CARPETS OFF AND GET THEN BONE DRY THEN FIT THEN ALL BACK IN AND FIT A NEW POLLEN FILTER , LUCKY ME ECU UNIT IS OK SO KIDS CHARGING ME £220 ALL IN SO NOT BAD I SAY .
Posted: Wed Nov 26, 2014 1:15 am
by SuprSi
Screw that, vax up as much as you can then just put a dehumidifier in the boot and a fan up front to circulate the air. Leave there for 24hrs or so and job done! You can probably hire the gear if you don't have it.
I had to do this after sitting on my key and winding all the windows down one night when it was pissing it down!
Do whichever you want but that sounds like a lot of effort.
Posted: Wed Nov 26, 2014 9:33 am
by brassy1975
ITS TRYING TO GET ALL THE SPONGE UNDER THE CARPET DRY PROPERLY COS IF YA DONT IT WOULD START TO SMELL AND GO MOLDY , LEAST I KNOW IT'LL GET DONE PROPERLY INSTEAD OF ME TRYING TO DO IT , AND WANTS £220 NOTES I SPEND THAT IN THE BOOKIES IN 10 MINS , HA
Posted: Tue Dec 02, 2014 10:44 pm
by brassy1975
well car all back to normal nice and dry , now just need a nice day to wash it and wax it ,,
