Nissan GT-R 4.3L GT800+ 327kmh flat tyre...
Posted: Fri Sep 12, 2014 12:49 pm
by mavada
Re: Nissan GT-R 4.3L GT800+ 327kmh flat tyre...
Posted: Fri Sep 12, 2014 1:39 pm
by bam_bam
Bit of tyre weld and new underpants will fix that.
Posted: Fri Sep 12, 2014 6:39 pm
by Surrey Sam
Had a P-Zero rear tyre let go on a Jag at 110+mph...that certainly was an eye opener. Wouldn't like to think what went through his chocolate starfish at over 200mph :shock:
Posted: Fri Sep 12, 2014 7:36 pm
by adsgreen
he did the right thing though - ease off and not doing anything ham fisted... just let the car slow down and try to keep it in the right direction.
Many people would have instinctively applied the brakes and then that would have been interesting!
Posted: Fri Sep 12, 2014 8:55 pm
by Graeme4130
adsgreen wrote:he did the right thing though - ease off and not doing anything ham fisted... just let the car slow down and try to keep it in the right direction.
That guy mist have a cast iron set of balls... And quite possibly a very tight sphincter
Posted: Fri Sep 12, 2014 9:13 pm
by bam_bam
Be interested to see how it would've behaved with all electrics off... and in RWD mode. I guess it's safe to assume he wasn't on run-flats?
Posted: Sat Sep 13, 2014 12:14 am
by S4Player
bam_bam wrote:Be interested to see how it would've behaved with all electrics off... and in RWD mode. I guess it's safe to assume he wasn't on run-flats?
He was on oem Dunlop run flats bam
Posted: Sat Sep 13, 2014 11:48 am
by adsgreen
That's the problem with the higher speed ratings.
it just says rated for over 186 mph.
It could be 187mph... it could be 250mph... it doesn't matter. It would still have the same code so you can't infer the actual top speed of the tyre from the sidewall... just that it'll be fine at 186.
Suggests by the way it let go that it was quick - unless the pressure sensors were disabled (stupid to do on a run flat equipped car) then it should have been going mental if the pressure dropped. So either hit some debris of the tyre was simply over it's design limit and overheated.
