Removing 'rounded off' hex bolts from steering wheel
Posted: Mon Jun 03, 2013 7:23 pm
by TimDogg
Guys,
I have a MOMO 'Team' wheel from my new Elise that I am going to sell (280 mm) and buy the 300 mm one but someone has had a go at the bolts and they are rounded off (4 out of 6) so that an allen key or torx bolt can't turn them. Anyone had this issue? Either I MIG weld (not that I have that in my back pocket) or I could drill into them and use an 'easy out' tool but apart from that has anyone ever successfully done this themselves - is it a specialist job? They were rusted and were tightened to within an inch of their life!
Re: Removing 'rounded off' hex bolts from steering wheel
Posted: Mon Jun 03, 2013 7:42 pm
by Batfinnk
Are the heads flush or raised? If raised you could try filing a flat into them then unscrewing. Another option is to try a slightly larger torx bit?
Posted: Mon Jun 03, 2013 7:44 pm
by TimDogg
They are flush unfortunately - I could drill the heads off, remove the wheel and then use pliers on whatever is left but I think it won't be much.
Posted: Tue Jun 04, 2013 2:57 pm
by redrsr
Batfinnk wrote: Another option is to try a slightly larger torx bit?
+1
Use next size up Torx bit, line up with corners and tap in with hammer, tapping often loosens seized threads too
Posted: Tue Jun 04, 2013 5:12 pm
by Batfinnk
Where abouts are you Timdogg? I have some stuff on the van which is awesome for loosening stuck threads.
Posted: Tue Jun 04, 2013 5:16 pm
by Mr Footlong
+1
Done the same for the exact same problem before and has worked more often than not. I have also drilled the heads too and there was just enough to grab on too. Also, if the boss just has a rubber etc cover over it, once the steering wheel if off and you remove the cover, the underside of the bolts are usually fairly well exposed (normally only 3-4 support arms in the way in my experience), giving you various options to finish removal.
Posted: Tue Jun 04, 2013 9:51 pm
by TimDogg
That's some great advice re. the torx bolt and taping it in - I'm going to try this, I'll let you know how I get on.
Thanks!
Posted: Tue Jun 04, 2013 9:52 pm
by TimDogg
Batfinnk - Anglesey, nobody lives near here but thanks for the offer, it's very much appreciated!
Posted: Tue Jun 04, 2013 10:05 pm
by Batfinnk
:thumb:
