Hi guys , own a B5 rs4
Went back to her after 11 years wouldn’t start
Got to bottom fuel tank pipes had broken to bits so replaced all them with a Bosch 044 genuine pump.
Now the connector isn’t showing any power that plugs on the pump
Checked the fuses on side panel and under drivers ?
Could anyone recommend a decent close by mechanic, located in Halifax West Yorkshire
HELP NEEDED 004
Re: HELP NEEDED 004
Hi there! Sounds like you’re dealing with a frustrating issue—it's great that you’ve already replaced the fuel tank pipes and pump. If there’s no power at the pump connector, it might be worth checking the fuel pump relay, as it could be the culprit. Also, double-check the ground connections and ensure there’s no corrosion affecting the electrical circuit.
Re: HELP NEEDED 004
Hmm. Definitely worth getting a specialist to look at it after sitting so long.
