Just a quick one:
I read that the standard oem factory wheel sizes of the rs4 B7 is 9jx19j with 255/35/19 tyre. Is this correct and if so is that for both front and rear???
Are the oem ones speed line, 9J x 19H2, ET52??
I only ask because when looking at a car to buy I don’t want one with none oem replicas on that just fold when hitting pot holes or speed bumps.
Just want to get it right so it’s not an unnecessary bill once purchased.
Hope this makes sense!
RS4 B7 wheel sizes???
Re: RS4 B7 wheel sizes???
Do the rears look as though they are sat to deep in this or is it just the angle???
I mean they look like they aren’t wide enough and don’t fill the arches???
To fit my car's wide wheel with appropriate Tyres Shrewsbury, I visited SP Tyres. Their range of tyres is excellent to meet with the requirement of all alloy and wide wheels.
Offset is ET29 for the OEM 19" wheels. As standard the outside face of the wheel does sit inboard of the arch, this is to allow the fitment of snow chains.
8mm front and 10mm rear is the normal size spacers you can run without rubbing but it depends on tyre manufacturer.
I run 8mm H&R all round with the ride height set to SS+ (KW V3) and Michelin PS4S with no issues.
You can remove the upper arch liner screw at the front if you find it rubs with the 8mm spacers.
Misano Red RS4 B7 Avant
