Repairing nailed tyre-Is it safe for high performance tyres?
Golich
Post by Golich » Mon Oct 03, 2005 1:30 pm
Bummer - Brand new set of Toyos on my RS4 last month. Came out this morning to find one of the rears flat. Found a nail in it.
I know they can repair nailed tubeless tyres with a wedged shaped rubber bung pushed from the inside out and its glued. Or perhaps a tube?
I'd have no probs with this on a tractor or 4x4 but uneasy about my RS4. Given the speed and torque this baby can put out. I'm thinking you don't know what its done to the wire/mesh internals of the tyre.
Anyone got any experience or thoughts on this? :?
BRETTCOLLINS
RE: Repairing nailed tyre-Is it safe for high performance ty
Post by BRETTCOLLINS » Mon Oct 03, 2005 1:35 pm
As long as it isn't to near to the sides should be fine. had one repaired on my S4.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
DaveP
Post by DaveP » Mon Oct 03, 2005 1:36 pm
I've had bike tyres repaired and they've been fine...never had a problem after the repair - even at some scary speeds (not on a public road of course)...
DaveP...
Audi Allroad - Daily slogger
S1 Exige - Track beast
PhilT
RS246.com
Post by PhilT » Mon Oct 03, 2005 1:53 pm
I've had Toyos repaired, should be ok.
DavidT
Post by DavidT » Mon Oct 03, 2005 2:16 pm
Yeah, I'd do it. Watched them do one once, they use a drill to create a cone for the plug to go in (with glue), then they put a patch over it on the inside too. Probably the strongest part of the tyre.
Leave it on the back.
No Tubes.
TarmacTerrorist
Post by TarmacTerrorist » Mon Oct 03, 2005 6:02 pm
iirc the maximum size hole they can repair using this method is 6mm which is quite big. If they thought it was unsafe they wouldn't fix it for you, and why they wont touch a hole near the side wall or the tyres shoulder.
Too much is bad.
Plenty is better.
Golich
Post by Golich » Wed Oct 05, 2005 9:06 am
Cheers guys. The nail is well away from the side wall. I'll look into it today.
Dippy
Post by Dippy » Wed Oct 05, 2005 10:46 pm
TT's right, tyre fitters won't repair unless it's safe to do so. IIRC the unsafe area is the 25% nearest the tyre wall.
2001 Silver S4 Avant
kcsun
Post by kcsun » Wed Oct 05, 2005 10:54 pm
What is it with Toyos - had mine 6 days and same as Golich Flat rear this morning, 2" no8 screw repaired by above method by 9am £10
kc
Golich
Post by Golich » Sat Oct 08, 2005 9:22 pm
Got the tyre repaired today by Kwik Fit. 15 min job and no charge.
:jump_clap:
I watched what they did and I feel confident it's a good repair.
I'm glad I fitted the spare RS4 wheel tho. as they told me if I'd filled the tyre with the Audi sealing gunk, they wouldn't have repaired the tyre as they can't get their patch/bung combo to stick to the tyre wall after that gunk has been on it - So take note! :shock:
PhilT
RS246.com
Post by PhilT » Sun Oct 09, 2005 10:16 am
Not always the case... My tyre guy preps the area with a high speed wire brush.
Golich
Post by Golich » Sun Oct 09, 2005 12:08 pm
Yeah that's what I though. Surely they just have a little bit more cleaning/prep of the rubber. I agree with you Phil. Its a lame excuse on thier part.
On reflection they weren't the sharpest tools in the box. They took the tyre off the rim from the outside of the rim. When I asked them about this they stopped and fecked about for long enough with a piece of plastic so they didn't damage the paint work and after all that they still attempted to put the tyre back on the rim from the outside. They then changed to the inside when they spotted me watching them. All this from guys that do this day in day out :?
Return to “General Car Chat”
Users browsing this forum: No registered users and 141 guests
