2.0 TFSI B7
boombastik
2.0 TFSI B7
Post by boombastik » Tue Jun 07, 2016 7:44 am
can someone help me identify the PCV crank case breather on the 2.0 TFSI engine apologies this isn't RS related
my friends car and when I open the oil cap the engine is in vacuum so ross tech suggests that the crank case breather is fooked
RS4 B7 Saloon Milltek Cat back, CAF with piper cross panel, Wrapped optics black, Satin black wheels, TRUPS LED front DRL's & sides, goodridge braided hoses, H&R 10/15mm spares front/rear
Bilstien B16 coilovers with H&R anti roll bars
MRC stage 2 deflapped, precat gutted 439ps 481nm torque
1/4 mile time 12.884sec
My clutch replacement write up can be found here viewtopic.php?f=35&t=116929&start=15
pule333
Re: 2.0 TFSI B7
Post by pule333 » Tue Jun 07, 2016 8:01 am
Do you see that ally metal plate with two black pipes? That's where the OEM pcv valve is.
By the way this kit I have is for sale if you friend wants to eliminate this problem once and for all ;)
RS4 B7 aka Vinnie
boombastik
Re: 2.0 TFSI B7
Post by boombastik » Tue Jun 07, 2016 8:09 am
cheers
so guessing stock item is this https://c1552172.ssl.cf0.rackcdn.com/346248_x800.jpg
pule333
Re: 2.0 TFSI B7
Post by pule333 » Tue Jun 07, 2016 8:10 am
Yes
RS4 B7 aka Vinnie
boombastik
Re: 2.0 TFSI B7
Post by boombastik » Tue Jun 07, 2016 8:11 am
perfect cheers
TobyRS4
Re: 2.0 TFSI B7
Post by TobyRS4 » Tue Jun 07, 2016 6:23 pm
I'd recommend the external oil catch tank type like pictured, had the same issue on a mk5 golf gti 2.0 tfsi and fitted a catch tank as above which cured the problem
Sprint Blue B7 RS4 - Black/Titanium optics, Anthracite OEM 19's, De-resonated OEM Exhaust, TTRS FBSW, MRC Stage 2 De-flapped manifold, Full Carbon Clean, MRC Stage 2 Re-map, 431.5 BHP...... must...not...spend....more...
boombastik
Re: 2.0 TFSI B7
Post by boombastik » Tue Jun 07, 2016 6:34 pm
TobyRS4 wrote:I'd recommend the external oil catch tank type like pictured, had the same issue on a mk5 golf gti 2.0 tfsi and fitted a catch tank as above which cured the problem
Don't think she's that bothered as long as it fixes the issue.
pule333
Re: 2.0 TFSI B7
Post by pule333 » Tue Jun 07, 2016 6:34 pm
Like I said, pm me if interested.
RS4 B7 aka Vinnie
Return to “General Car Chat”
Users browsing this forum: No registered users and 93 guests
