Brake upgrades
- Trader (Expired)
Brake upgrades
Hi Folks
We are back up and running after the Xmas break and are taking orders for brake kits , please see our FB page or website
for more details we hope to be able to help with your braking needs .
- John Johnson
- 5th Gear
Re: Brake upgrades
How much are they then as there's nowt on your website ?
Current toys in the garage
B7 avant in Daytona with ceramics and a few other goodies and lowwwww miles
Ur quattro. lago Blue
Ur quattro. Mars red
Rs1600i
Transit custom sportvan
http://youtu.be/FWBUl7oT9sA
Rs1600i
- Trader (Expired)
Re: Brake upgrades
Front discs to fit std bells £550.00 per pair Rear on aluminium bells £510.00 per set .John Johnson wrote:How much are they then as there's nowt on your website ?
Re: Brake upgrades
...fronts on custom bells? For example, a good disc mated to a custom aluminium bell to fit an RS6 (C5 or C6 - both have different ET).Vari Perf Brakes wrote:Front discs to fit std bells £550.00 per pair Rear on aluminium bells £510.00 per set .John Johnson wrote:How much are they then as there's nowt on your website ?
Re: Brake upgrades
Do you do other designs to the discs? I.E drilled? Just not a massive fan of the gone wrong Nike swoosh.
S4 b5 340bhp
Rs4 b5 507bhp
Rs6 c6 project 800bhp
S3 stock daily work hack
Rs4 b5 507bhp
Re: Brake upgrades
You have the possibility of drilled discs cracking.
- Trader (Expired)
Re: Brake upgrades
We avoid drilled discs as they are prone to surface cracking around the holes which some people see as a major issue but generally do not cause any problems .C_J wrote:Do you do other designs to the discs? I.E drilled? Just not a massive fan of the gone wrong Nike swoosh.
- Trader (Expired)
Re: Brake upgrades
Hi we do a378mm disc that we could fit to your std bells they go for £570.00 per set ,I will check if we can do custom bells ,bam_bam wrote:...fronts on custom bells? For example, a good disc mated to a custom aluminium bell to fit an RS6 (C5 or C6 - both have different ET).Vari Perf Brakes wrote:Front discs to fit std bells £550.00 per pair Rear on aluminium bells £510.00 per set .John Johnson wrote:How much are they then as there's nowt on your website ?
This should not be an issue .
- Trader (Expired)
Re: Brake upgrades
Based in Bicester but let me know what you are looking for as most parts are done to order at the moment .bam_bam wrote:Where are you lot based?
