Brake upgrades
Vari Perf Brakes
Trader (Expired)
Brake upgrades
Post by Vari Perf Brakes » Wed Jan 06, 2016 11:08 am
Hi Folks
We are back up and running after the Xmas break and are taking orders for brake kits , please see our FB page or website
for more details we hope to be able to help with your braking needs .
Re: Brake upgrades
Post by bam_bam » Wed Jan 06, 2016 1:09 pm
Interesting!
FON.
I'll do rule 1 for you.
John Johnson
Re: Brake upgrades
Post by John Johnson » Wed Jan 06, 2016 1:17 pm
How much are they then as there's nowt on your website ?
Current toys in the garage
Ur quattro. lago Blue
Ur quattro. Mars red
Rs1600i
Transit custom sportvan
http://youtu.be/FWBUl7oT9sA
Vari Perf Brakes
Trader (Expired)
Re: Brake upgrades
Post by Vari Perf Brakes » Thu Jan 07, 2016 12:01 pm
John Johnson wrote:How much are they then as there's nowt on your website ?
Front discs to fit std bells £550.00 per pair Rear on aluminium bells £510.00 per set .
Re: Brake upgrades
Post by bam_bam » Thu Jan 07, 2016 12:32 pm
...fronts on custom bells? For example, a good disc mated to a custom aluminium bell to fit an RS6 (C5 or C6 - both have different ET).
C_J
Re: Brake upgrades
Post by C_J » Thu Jan 07, 2016 2:01 pm
Do you do other designs to the discs? I.E drilled? Just not a massive fan of the gone wrong Nike swoosh. :|
S4 b5 340bhp
Rs4 b5 507bhp
Rs6 c6 project 800bhp
S3 stock daily work hack
Re: Brake upgrades
Post by chunky79 » Thu Jan 07, 2016 2:04 pm
You have the possibility of drilled discs cracking.
Vari Perf Brakes
Trader (Expired)
Re: Brake upgrades
Post by Vari Perf Brakes » Thu Jan 07, 2016 2:32 pm
C_J wrote:Do you do other designs to the discs? I.E drilled? Just not a massive fan of the gone wrong Nike swoosh. :|
We avoid drilled discs as they are prone to surface cracking around the holes which some people see as a major issue but generally do not cause any problems .
Vari Perf Brakes
Trader (Expired)
Re: Brake upgrades
Post by Vari Perf Brakes » Fri Jan 08, 2016 2:19 pm
Hi we do a378mm disc that we could fit to your std bells they go for £570.00 per set ,I will check if we can do custom bells ,
This should not be an issue .
Re: Brake upgrades
Post by bam_bam » Fri Jan 08, 2016 2:26 pm
Where are you lot based?
Vari Perf Brakes
Trader (Expired)
Re: Brake upgrades
Post by Vari Perf Brakes » Sun Jan 10, 2016 3:31 pm
bam_bam wrote:Where are you lot based?
Based in Bicester but let me know what you are looking for as most parts are done to order at the moment .
Return to “General Car Chat”
