2012 audi rs4 front brake pads ceramic
Hello people I have recently brought a 2012 audi rs4 the brake pad light had come up on the instrument cluster and I took a look and the front ones are really low, I have browsed the Internet for some pads but can't find any anywhere Iv called tps etc and they only do non ceramic brake pads so I presume its dealer only does anyone have any idea what sort of price these brake pads are and where I can get them from apart from audi thx for your help in advance
- Revolution
- Trader (Expired)
Re: 2012 audi rs4 front brake pads ceramic
Search for littledevils on here as he sticks them..
http://www.revolution247.com
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
Sold but never forgotten:
2014 RS4 Sepang Blue
2015 VW Golf-R
2012 RS3 Sepang Blue
RS4 B7 Avant Daytona
2002 Renault Avantime V6
2006 2-door Impreza STi
2009 TT TDi Quattro
10 Subaru's inc 22B type UK
Renault Clio V6 MK2
Civic Type-R's Mk1, 2 and 3
205 GTi 1.6 & 1.9 Gutmann
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
- Surrey Sam
This thread makes no sense really, other than the OP needs new pads.
Do you have a Steel setup or a Ceramic one; what colour are your brake calipers, Grey or Black?
Calipers are grey
- Surrey Sam
Unfortunately Ceramic discs use a different type of pad compound to work together and that means less choice.
Stoke Audi will do a set for around £310, whilst the only after market solution I've heard that works with Porsche's ceramic discs is the Pagid RS29 brake pad. I'm yet to hear any Audi ceramic disc users utilise a pad other than the OEM one though.
If you don't mind me asking, how many miles have you covered on those pads?
Car has just covered 25,000 miles and didn't think they would be cheap rear pads are £85 from solihull audi which isn't too bad but front was quated £350 and wear sensors £59 a side!!
- Graeme4130
That's quite early to be replacing ceramic pads ?Aungkhin wrote:Car has just covered 25,000 miles and didn't think they would be cheap rear pads are £85 from solihull audi which isn't too bad but front was quated £350 and wear sensors £59 a side!!
Rears are steel, and nice and small, so pretty cheap in comparison
Due to the ridiculously huge cost of replacing the ceramic disc, I'd be very reluctant to use anything other than OEM pads fitted anywhere other than a dealer
- Surrey Sam
As above.
I shall be replacing mine with Audi ones, not worth the risk and the OEM performance is great anyway.
- Graeme4130
What's the miles on your pads Sam ?Surrey Sam wrote:As above.
- Surrey Sam
I don't honestly know Graeme, as my Ceramics came off another car I purchased which had done 60k. I could find no record of a pad change when investigating its history and they appeared to be around 2/3rds worn?Graeme4130 wrote:What's the miles on your pads Sam ?Surrey Sam wrote:As above.
Just can't believe the setup would have done over 60k on a single set of pads, although the pad backing plates were breaking out in rust and looked to be that sort of age. I want to get them replaced mainly because I don't want to risk getting down to the backing plate pins and ruining the disc face - like you can get with the steel B7 setup.
Previously, I've googled (is that a word now?) Porsche PCCB pad life and read experiences of great pad life. There just isn't any Audi experience out there that I could find.
- Graeme4130
My understanding is to expect 60-80 from the pads and 120+ from the discs
Porsche discs and pads are now the same material and design as Audi RS products, so life expectancy should be similar I'd hope (although you might argue that typically, porsche's get a harder life if someone's had the foresight to order ceramics
- geordie jay
- 5th Gear
wow sam I didn't realise you were using ceramics fella.
- Surrey Sam
Yeah, had them for about 4 months now Jay.geordie jay wrote:wow sam I didn't realise you were using ceramics fella.
Just 4 more options to go before I have every one in the brochure except the exclusive paint/interior, two of which I don't want anyway. I'm such a spec whore
Yes, so glad Audi didn't have the same issue as the PCCB's had to begin with - it could have killed all faith in Ceramic brakes. OK, 60-80k that's quite a bit, if mine are original then they're on the money.Graeme4130 wrote:My understanding is to expect 60-80 from the pads and 120+ from the discs
- geordie jay
- 5th Gear
Yeah, had them for about 4 months now Jay.Surrey Sam wrote:geordie jay wrote:wow sam I didn't realise you were using ceramics fella.
and a bitch don't forget that
Users browsing this forum: No registered users and 119 guests
