When to check engine Oil ?
raza_1
Post by raza_1 » Thu Mar 04, 2010 12:41 am
Hi All,
I have a question regarding when to check engine oil. I own an Audi S4 B6.
When I check the oil cold without the engine started, the oil dipstick shows the oil well over the max line.
However when I check the oil after starting the car and letting it run for 5 minutes, the oil dipstick shows the oil just above the minimum line.
Which reading should I be going by ?
thanks Raz
S4 B6 53
sonny
RE: When to check engine Oil ?
Post by sonny » Thu Mar 04, 2010 10:14 am
In The RS4 manual is states, that engine must be started, so warm, then switched off for 2 minutes, then checked. check your manual as It might be different, some cars have dip sticks meant for cold checks, others for hot checks.
raza_1
Post by raza_1 » Thu Mar 04, 2010 9:04 pm
Thanks, will check the manual.
S4 B6 53
baylissboy
Post by baylissboy » Sun Mar 07, 2010 10:18 pm
All Audi's are checked in the same way.
Vehicle should be standing on level surface, engine should be upto operating temp, oil temp should be at least 60 degrees C (100-110 degrees on RS4/6 & R8), switch engine off & allow to stand for approx 2 minutes (never more than 10 mins), then take reading.
Teutonic_Tamer
Post by Teutonic_Tamer » Fri Apr 02, 2010 4:02 pm
baylissboy wrote:All Audi's are checked in the same way.
No they aint! The four pot TFSIs can be checked either hot or cold!
Sean - Independent Motor Vehicle Tech (ret'd)
'07 Audi B7 RS4 (with ceramic brakes) - WOW!
'06/7 VW Golf Mk5 GTI 2.0T FSI DSG 5dr
'03 Audi B6 S4 4.2 V8 6sp man (gone)
Return to “General Car Chat”
