Don't be silly, there's a 5l can of oil holding it up at the backok guys but is it me or is this car floating in the air
@ Grizz, you've got damn good eyes, I don't see anything on this side of the rear of the car?
Well either the v8 lump has different bell profile/holes and/or the spigot shaft is too long...... maybe tdiquattro could ask him ...?aposegil wrote:damm thin i need to get my eyes checked but did freak me out for a second.
Anyhow more info/pics and why adaptor plate had to be welded on would be great
yep thats correct,it must be using later/different fly and clutch thenSiena wrote:The V8 motor does NOT need an adapter to mount to the 01A / 01E transmission.
The V8 uses the same holes the I5 / V6 use. The only one that uses the inner circle of holes is the I4.
That's more like a spacer - not really needed, unless it's got a huge DM flywheel, and with the clutch, protruded too far into the bellhousing.
Early manual S8 in Germany (AHC / AKH) use a SM flywheel, and do NOT require a spacer. Crank boss has the same dimensions as the RS6, and the same 10-bolt setup.
Only the later S8 with the 40V motor uses a spacer, due to the DM flywheel, and has an 8-bolt setup.
I thought the same too, only the later flywheel won't fit.quattronutter wrote:yep thats correct,it must be using later/different fly and clutch thenSiena wrote:The V8 motor does NOT need an adapter to mount to the 01A / 01E transmission.
Bingo!!kostas@aprgreece wrote:Correct the spacer is for the flyweel.
Early S8 (32V) flywheel and clutch. You can also use the clutch from the UrS6 / UrS6+, or even a Southbend clutch designed for SM flat flywheel, as used on big power S2.musty1 wrote:kostas welcome to the forum what ecu are you using ?
@ Siena so what flywheel and cultch would you use to mate the rs4 box to a rs6 engine?
Users browsing this forum: No registered users and 65 guests
