EML on. P2096 and P16BA. Any advice would be helpful. Thanks
Posted: Tue Aug 12, 2025 9:20 pm
by R5SAM
Hi,
I had the EML light come on my C7 RS6 Performance with the following codes:
P2096- Post catalyst fuel trim system bank 1 too lean.
P16BA- Coolant pump for charge pressure cooler dry running
Any ideas where I should start? Any help would be really appreciated. Many thanks!
Re: EML on. P2096 and P16BA. Any advice would be helpful. Thanks
Posted: Mon Aug 18, 2025 7:30 pm
by Tadass910
Hello, have you tried delete them? And see if they come back?
Posted: Thu Oct 16, 2025 6:18 pm
by RS6108
I've had P2096.
Only that code with nothing else so i will be putting on a new post cat lambda on that bank. from some research it does seem a common item to fail
Posted: Thu Oct 16, 2025 7:32 pm
by Tadass910
I've had P2096.
Have you solved coolant problem code?
P2096 I have already for years, just delete it and go no harm. I have that code popping from time to time when going on low rpms, but been deleting it and deleting. No change in performance
Posted: Mon Nov 24, 2025 11:03 pm
by RS6108
I have since replaced the lambda and put a new set of spark plugs in.
Will see how it goes. Car is running very nice.
Posted: Wed Nov 26, 2025 8:46 am
by Tadass910
Thanks for update
