No warm air only cold
Posted: Fri Nov 03, 2023 10:57 pm
by Tadass910
Hello, recently my car started blowing only cold air through the air vents but not hot air, even when I set 28 plus it’s not blowing hot air, what could be an issue?
Re: No warm air only cold
Posted: Sat Nov 04, 2023 1:29 pm
by morski
Check if you have hot water coming into the cabin area by feeling the pipes in the plenum chamber. There is a valve there which could be the issue
Posted: Sat Nov 04, 2023 8:33 pm
by Tadass910
morski wrote: ↑Sat Nov 04, 2023 1:29 pm
Thanks Morski, where those pipes are? More over I scanned today with carista and got those codes: I think I need a visit to my dealer. Also my front window is foggy when driving in a rainy conditions, only helps when using ac with to defrost window but it’s very cold inside a car
Posted: Wed Nov 08, 2023 11:59 pm
by morski
Take off the panel under the windscreen. You will see the 2 pipes entering the cabin area from the engine bay. there is a pump there as well so check the temp on the pipe pre and post pump.
Until you get the air temp sorted coming into the cabin you will have condensation issues in the cabin
Posted: Sat Nov 11, 2023 8:20 am
by Tadass910
morski wrote: ↑Wed Nov 08, 2023 11:59 pm
Thanks m8, fixed appointment at Audi
Posted: Fri Nov 17, 2023 5:55 pm
by Tadass910
It’s strange but it started warming up, not sure what happened….but it fixed itself
