Injector replacement - massive potential bill - any experience?
Posted: Thu May 18, 2023 1:50 pm
Hello chaps,
My car has developed the hot start issue where you have to prod the throttle to get it to start. My main dealer couldn't diagnose the problem and said they tested the high pressure fuel pumps which seemed to be operating normally - they found some other issues and changed the temp sensor and lambda probe and returned the car.
It was ok for a couple of weeks - then the issue returned every time i would re-start the car - high idle at around 1400rpm, smells of fuel and then the EML came on and it was running really lumpy.
Car has gone back in to the dealer - retested the fuel pumps which are reading normally and are now saying its an injector problem. They are proposing replacing all the injectors which they say required full engine and gearbox removal and a bill of about 10 grand.
Given all the previous problems i have had with this car - and the fact that the same dealer has done all servicing and maintenance for it's entire life - and it's been back in 3 times in 5 months for engine problems following them replacing the turbo which failed immediately after they did the oil strainer recall, the service manager is asking Audi UK for a contribution...
So my question is do they really need to take out the engine and gearbox to replace the injectors - which they suggest will be around 23 hours labour? Even if Audi meet half the cost this is another massive chunk of change for what's easily the most unreliable car i have ever owned.
Anyone had to do similar with their car - what was the cost for doing it?
Matt.
Matt.
