Page 1 of 2
DRC refill
Posted: Fri Oct 14, 2022 5:13 pm
by Tadass910
Hello, anyone did it? Any ideas how much it can cost if it’s only front? And if all needed? Thanks
Re: DRC refill
Posted: Fri Oct 14, 2022 5:44 pm
by Daveperc
Since the DRC circuits are diagonal across the car I fail to see how you think "it's only the front"!! :drink: :drink: :bigwave:
Re: DRC refill
Posted: Fri Oct 14, 2022 8:23 pm
by Revilo
It’s about £200-250 at Audi to replace fluid and pressurise
Re: DRC refill
Posted: Sat Oct 15, 2022 10:59 pm
by Rich85
Had mine done under warranty. As mentioned it’s a diagonally linked system with 2 valve assemblies at the rear and these can get damaged when pressure is lost.
I had knocking from the front right and rear left. Dealer refilled and pressurised (over 20+ bar) and has been OK since, so I may have been lucky and not damaged anything.
Re: DRC refill
Posted: Sun Oct 16, 2022 9:17 am
by Tadass910
Thanks everyone for information, I have this knocking https://youtube.com/shorts/-I4jIfXouSs?feature=share
https://youtube.com/shorts/x38UUMcTA6I?feature=share
Not sure is it drc or something else, and this noise I get when I turn to the left hard when one wheel especially more higher than other, same sometimes happens when I turn to the right also when car not in horizontal position and one wheel higher than others
Re: DRC refill
Posted: Sun Oct 16, 2022 12:21 pm
by morski
Check your arb links. can also cause a knocking noise.
Re: DRC refill
Posted: Wed Oct 19, 2022 7:56 pm
by Tadass910
Thanks for mentioning that, I definitely going to Audi dealer, that I have that noise and point them about that it could be drc refill time or these arb links. Or should I not mention them anything just tell that I have that knock sound, I can show on a video
P.S you mean those arb links in a picture I posted?
Or it’s this item https://m.autodoc.co.uk/ridex/8101055
Re: DRC refill
Posted: Wed Oct 19, 2022 10:29 pm
by morski
Yes those are correct. As you have DRC part no is 4H0411317C. I try to use a decent brand such as Lemforder, Febi, Meyle
Re: DRC refill
Posted: Thu Oct 20, 2022 10:25 am
by Tadass910
Re: DRC refill
Posted: Sun Oct 23, 2022 10:44 am
by super7
Same for me… I had mine done under warranty. It was only 2 bar under but had a noticeable knock on my rear left. Back up to 20+ bar and it went. Had the same issue with my RS4 B7. Tech at Audi said the knock is perfectly normal on DRC. Although my OCD on noises can’t cope with it!
Re: DRC refill
Posted: Tue Oct 25, 2022 2:52 pm
by Tadass910
So tech Audi said knock is perfectly normal? But you shouldn’t hear any knock if everything ok
Re: DRC refill
Posted: Thu Nov 03, 2022 10:58 pm
by stuartbarriskell
Agree 100%... the suspension shouldn't knock at all if everything is sound.. I've just found that out when I had a strut replaced the whole system drained and refilled..not a sound from it.
Sent from my SM-G998B using Tapatalk
Re: DRC refill
Posted: Wed Nov 09, 2022 4:41 pm
by Tadass910
I had a strut replaced.
Can you tell me more pls?
Re: DRC refill
Posted: Fri Nov 11, 2022 12:46 am
by stuartbarriskell
I'm mentioned here, what do you need to know
Re: DRC refill
Posted: Sun Nov 13, 2022 11:10 am
by Tadass910
:thumbs: Thanks
