ABS Control Module - where to buy
Posted: Thu Jun 09, 2022 6:38 am
by rs64u
Anyone knows of a website that I can order the Audi RS6 C7 and module .
It’s a bit expensive and I am afraid to buy a used one as it might fail and this part requires programming .
Anyone has good contacts to where I can order one,
In my country it’s very expensive and the USA it’s cheaper but it’s only for RS7 and I am not sure if we can use that
Thank you
Re: ABS Control Module - where to buy
Posted: Thu Jun 09, 2022 3:57 pm
by Golfather
The ABS is not specific to the RS6 or RS7, and is shared across other models
A used one will work, and can be coded to your car.
Have a look at the HW part number of your module and search on ebay etc for an equivalent part number.
eg 4G0 907 379 T
Posted: Fri Jun 10, 2022 1:22 am
by rs64u
Thanks mate
Posted: Fri Jun 10, 2022 1:26 am
by rs64u
4G0614517BABEF is mine ,
Can I use : Part Number: 4G0907379ADREP
Supersession(s): 4G0-907-379-AD-REP; 4G0998375AF
https://parts.audidtla.com/p/Audi_2017_ ... ADREP.html
Posted: Fri Jun 10, 2022 1:42 am
by Golfather
Where did you get 4G0614517BABEF from? Is that stamped on the unit? Also check the SW with a scanning tool such as
VCDS.
There are 2 part numbers which should match, 4G0614517BABEF which is the HW number and 4G0907379AD which is the SW for that pump
The link you have given is not a supercession for 4G0614517BABEF. This part number is for the complete unit (hydraulic and electronics)
4G0907379ADREP is listed as a repair unit for that pump which is only the electronics module, so if that is what is faulty then yes it could be fitted to your existing hydraulic pump
Posted: Fri Jun 10, 2022 2:18 am
by Golfather
Interestingly this unit which is not listed for your specific car but still a RS7 is 4G0614517AM HW and 4G0907379T SW
https://www.ebay.com/itm/125360049843
The parts catalogue lists the repair kit for that abs pump has now also superceded to 4G0907379ADREP, which is the same as the repair kit for your pump 4G0614517BABEF
So in theory you could run the electronics of that ebay pump with your pump!
Posted: Fri Jun 10, 2022 2:52 am
by rs64u
Golfather wrote: ↑Fri Jun 10, 2022 1:42 am
VCDS.
I called the local dealer and he shared with me that part number .
I have yet to see the ABS module part number as it’s still in the vehicle .
Posted: Fri Jun 10, 2022 2:53 am
by rs64u
Golfather wrote: ↑Fri Jun 10, 2022 2:18 am
Thanks Mate ,
This parts are sure costly
Posted: Fri Jun 10, 2022 3:17 am
by rs64u
Thanks Mate ,
Posted: Fri Jun 10, 2022 3:18 am
by rs64u
Sorry for the repeat messages
Posted: Tue Jun 28, 2022 6:47 am
by rs64u
4g0 907 379 t , is from my vehicle !
The eBay unit , I bought can’t be used !
