Fuel Issue
Posted: Tue Sep 28, 2021 7:18 am
by ShaneyB
Hi guys,
Probably been asked before but I'm in a mad rush. Had my C7 almost two years and I've only used V-Power to fill up. I'm concerned now that I won't be able to get any with the tanker driver shortages and I don't have enough in the tank to go searching around. What is the minimum grade (RON) I can safely use without causing any issues please?
Thanks in advance.
Re: Fuel Issue
Posted: Tue Sep 28, 2021 9:30 am
by Saudirick
Absolutely fine. Have a look on the inside of your fuel filler. It says 95ron minimum which is normal unleaded. Just go back to super unleaded at the next opportunity
Re: Fuel Issue
Posted: Thu Sep 30, 2021 10:00 am
by Tadass910
98 always
Re: Fuel Issue
Posted: Thu Sep 30, 2021 10:08 am
by ShaneyB
Thanks guys, I thought 98/99 but it does say 95 minimum on the fuel cap. Absolutely no fuel available anywhere near me at the moment though so I'm stuck at home with the Mrs.
Re: Fuel Issue
Posted: Thu Sep 30, 2021 1:49 pm
by morski
Goverment is a shambles for creating this mess
Re: Fuel Issue
Posted: Fri Oct 01, 2021 9:09 am
by ShaneyB
Just to confirm guys,
My warranty wouldn't be invalid if I use 95 RON as it states it's the minimum requirement in the filler cap?
Re: Fuel Issue
Posted: Fri Oct 01, 2021 10:13 am
by Saudirick
You could always put normal unleaded in with an octane booster if you are worried about it
Re: Fuel Issue
Posted: Fri Oct 01, 2021 10:20 am
by ShaneyB
Managed to get to station with Esso Supreme + 99 RON so got £35.00. Relieved.
I do wonder if they changed the rule to let you fill up to max it would ease the panic a bit?
Cheers all, much appreciated as always.
Re: Fuel Issue
Posted: Thu Nov 25, 2021 12:47 pm
by VEA
Government or the press?
