VCDS Fault Code Help
Posted: Wed Jul 29, 2020 6:58 am
by sammi_s
Hey guys, I recently bought a used 2014 C7 RS6 Avant and I have these fault codes and I am trying to get rid of them or repair / reprogram but no idea on how to proceed.
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 1B 20 22 28 36 3B 3C
42 44 46 47 52 53 55 56 5F 62 65 6C 6D 72 85 8B 8E 8F 90 BA
46-Central Conv. -- Status: Malfunction 0010 Is this just a bad alarm, or the alarm is dead !
5F-Information Electr. -- Status: Malfunction 0010 I have no clue what this means or how to fix it
6D-Trunk Elect. -- Status: Malfunction 0010 I really need help with this one, I tried to do Adapt angle and it stays as unkown and, the trunk works perfectly with the button and all is fine but the code is there, also the cover doesnt retract like before but when i test it individually it does.
BA-Motor Mounts -- Status: Malfunction 0010 Typical 4.0T bad mount Im guessing
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Part No SW: 4H0 907 064 DT HW: 4H0 907 064 DT
Component: BCM2 2.0 H35 0510
Revision: 00002001 Serial number: 0312359906
Coding: 013A0E20A0B93095833009840E0312470000000000000000000000000000
Shop #: WSC 02391 785 00200
VCID: 7EF39408E9FD9B7679-802A
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J245 PS20.008 H02 0007
Serial number: WOO2327218%
Coding: 901F00
Subsystem 4 - Part No SW: 4G0 947 135 K HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00004297376
Coding: 010000
Subsystem 5 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J394 PS20.008 H02 0007
Serial number: WOO2327225/
Coding: 801F00
Subsystem 6 - Part No SW: 3AA 962 243 B HW: 3AA 962 243 B
Component: GEB.F.Heckoef H16 0810
Serial number: 93002408
1 Fault Found:
01134 - Alarm Horn (H12)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 167
Mileage: 128375 km
Time Indication: 0
Date: 2020.07.28
Time: 16:28:16
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 764 K HW: 4G0 035 764 H
Component: H-BNT-RW H51 0732
Revision: -------- Serial number: 192H-0D7504137
Coding: 070D00010303E9EF75908B2E00000003740001020000000000
VCID: 2F6D794C7E17A2FEA2-807A
Subsystem 1 - Part No: 8R0 060 884 AS
Component: ROW 2013 0506
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDDD0023Y8W
Subsystem 3 - Part No SW: 4G1 919 610 F HW: 4G1 919 610 F
Component: E380 BDT C7 H20 0250
Serial number: 90349PGL00055
Subsystem 4 - Part No: 8R0 060 961 F
Component: CD-Database 5298
1 Fault Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 167
Mileage: 128375 km
Time Indication: 0
Date: 2020.07.28
Time: 16:28:15
Freeze Frame:
Text: KBD_FC7,KBD,A,fa,cc,1
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G9 959 107 B HW: 4G9 959 107 A
Component: HDSG-Modul H03 0143
Revision: 14003001 Serial number: 235301198
Coding: 097205C010
ASAM Dataset: EV_HDSGAu572 001022
ROD: EV_HDSGAu571.rod
VCID: 35614B24944B982EE8-8060
2 Faults Found:
0004 - No Basic Setting
B2010 00 [137] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 167
Mileage: 128375 km
Date: 2020.07.28
Time: 16:28:12
Voltage terminal 30: 13.67 V
0010 - Play Protection Active
B120B 00 [137] - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 167
Mileage: 128375 km
Date: 2020.07.28
Time: 16:28:12
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 HW: 4H0 907 145
Component: AEM - LEAR H07 0006
Revision: 00001001 Serial number: 97809002397000
ASAM Dataset: EV_AEMLearAU64X 002014
ROD: EV_AEMLearAU64X.rod
VCID: 66C3DC68996D23B691-8032
1 Fault Found:
1294 - Actuator 1 for Drivetrain Mounts
C1131 07 [009] - Mechanical Failure
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 167
Mileage: 128375 km
Date: 2020.07.28
Time: 16:28:15
any help would be greatly appreciated guys.
Re: VCDS Fault Code Help
Posted: Wed Jul 29, 2020 9:18 am
by Saudirick
Can you not just clear the fault codes? Drive around for a few days and read them again? Some may reappear but more likely they will not
Posted: Thu Jul 30, 2020 8:54 am
by sammi_s
Saudirick wrote:Can you not just clear the fault codes? Drive around for a few days and read them again? Some may reappear but more likely they will not
I already did that, it was my first step.
Anyways:
So I got the 5F code sorted out found a video on YouTube and worked great.
The 6D also is all fixed up now found a thread with no replies sent a message and got a reply and gave me the fix, basically recalibration was needed in a certain sequence.
The alarm, checked it and yes the backup battery inside of it has exploded and ruined the unit got a new one on the way.
The last is a motor mount and waiting for the 034 upgraded ones !
Posted: Thu Jul 30, 2020 10:04 am
by crapbag
Just seen this and glad you got it all sorted.
I’d of been little help if I’d seen it earlier anyway! Haha.
The only help I could possible give is on the load cover. Did you get that sorted? If not mine didn’t retract either. It turned out the little sliding clips weren’t there. Bought new ones. Fitted them in about 30secs and her presto auto open and close load cover.
https://www.ebay.co.uk/itm/133321829306
Part number 8W98689544PK
Hope it helps.
Craig.
Posted: Sat Aug 01, 2020 8:10 am
by Hop along scott
I have engine mount code on my c7 rs6 currently. Over £500 each plus vat and plus fitting. Ouch
