Brake pads/discs
Posted: Sat Jul 11, 2020 10:27 am
by Wattsm666
My brake pads now need replacing, which is the first set after 35,000 miles. Audi have suggested the discs need changing as well and I will get them measured, but does it sound right one set of pads = new discs as well
Re: Brake pads/discs
Posted: Mon Jul 13, 2020 12:58 pm
by Wattsm666
Someone else has given me a second opinion and confirmed the discs need changing, they are wavy/grooved. They also said some mercs only get 20,000 miles from a set of discs.
Posted: Mon Jul 13, 2020 8:50 pm
by Paddski
Wattsm666 wrote:Someone else has given me a second opinion and confirmed the discs need changing, they are wavy/grooved. They also said some mercs only get 20,000 miles from a set of discs.
Mine were changed at 26k so sounds right. Wish I had ceramics
Posted: Tue Jul 14, 2020 7:35 am
by wildbore
My front and rear discs were changed simultaneously with the first set of pads at around 28K. The front discs were changed due to wear, the rears due to corrosion arising from a lack of wear. There cars like to be driven hard, and I just don't do those sort of journeys.
Posted: Sat Jul 25, 2020 9:31 am
by LRB23
I had my front discs changed at 37,000 miles. They were worn to their absolute minimum. Conversely the rears didn’t need replacing according to the Audi report.
Posted: Mon Aug 03, 2020 10:14 pm
by koruki
yes, this is the most frustrating thing with this car, whenever you need pads you need disc$$$ at the same time, stupid design
Posted: Mon Aug 03, 2020 10:15 pm
by koruki
Paddski wrote: ↑Mon Jul 13, 2020 8:50 pm
Do ceramics last longer?
Posted: Tue Aug 04, 2020 1:12 pm
by Wattsm666
koruki wrote: ↑Mon Aug 03, 2020 10:15 pm
I believe they can last 100,000 miles plus. But check this out. If they get damaged can be very expensive to replace though
Posted: Tue Aug 04, 2020 1:16 pm
by MikeFish
Ceramic discs are meant to last around 100k miles. Problem will be when the car approaches that sort of mileage only an idiot will buy a car with ceramics unless they plan on swapping all 4 calipers, discs and pads for the steel versions which will still be relatively expensive compared to the cost of the car.
Posted: Tue Aug 04, 2020 1:19 pm
by MikeFish
Wattsm666 wrote: ↑Sat Jul 11, 2020 10:27 am
Sounds about right. I sold mine with 32k miles and original discs but 2nd set of pads. I bought a set of 410mm discs to replace the fronts but sold the car before they were manufacutred.
Posted: Tue Aug 04, 2020 9:44 pm
by Sunnyevo2
I just had to have my front discs and pads changed along with my rear pads. I took it to an Audi specialist in the end as needed it done asap as was driving to Cornwall. If it helps it cost around £1580, not sure if that's a good price but i needed it doing in a rush my light was on the dash.
Posted: Tue Sep 15, 2020 2:51 am
by one80
MikeFish wrote: ↑Tue Aug 04, 2020 1:16 pm
Sorry to jump in on your thread.
But is there any issue switching from CCB to steel rotors? Are they exactly the same size etc?
