Rear washer not working-f/p/footwelll damp?
Posted: Wed Mar 27, 2019 6:50 pm
by UrielsMachine
Noticed the rear washer wasn’t working after l had purchased the RS a few weeks ago and got home. Have been working away a lot and decided to investigate tonight...found that the front passenger footwell carpet is slightly damp. Is this connected? Bust hose under carpet?. Will be ringing the garage l bought it from tomorrow :audibash:
Jas 👍
Re: Rear washer not working-f/p/footwelll damp?
Posted: Wed Mar 27, 2019 6:56 pm
by Markwes
Don’t suppose you have a Pan sun roof by any chance?!
Posted: Wed Mar 27, 2019 7:41 pm
by Daveperc
I'm guessing the layout is the same as the old C5. There's a joint in the pipe somewhere near the Pax door - on the C5 you simply took up the door trim and could access it quite easily.
Surprised they haven't fixed it given that it's an obvious design weakness! :audibash:
Posted: Wed Mar 27, 2019 9:19 pm
by Anth
No connection the hose wouldn't be able to leak internal . Really common for the jet nosel to corrode and fail will be a £4 fix at Audi to change out when it's in .
Pass footwell, you are the third person to mention this in as many months . Theres a few posts on this of late :audibash: . Get straight on to them its a major design fault .
Posted: Wed Mar 27, 2019 10:24 pm
by UrielsMachine
Right. Yep l have the pan roof. Door trim. What’s that. Thought the hose would have ran through the footwell. What’s the design fault with the passenger footwell?
All replies most appreciated. I’ve had previous experience with water in Audi footwells which has fried the electrics so l need to get to the bottom of this ASAP.
Cheers lads.
Jas 👍
Posted: Thu Mar 28, 2019 9:17 am
by Anth
Check this recent post by Johny on footwell leak (DS)
viewtopic.php?f=76&t=131367
As your car is just purchased recently the dealer would have obligation to sort this out for you .
Another ;
viewtopic.php?f=76&t=131256
viewtopic.php?f=76&t=131162&p=906919&hi ... ll#p906919
Posted: Thu Mar 28, 2019 11:37 am
by UrielsMachine
Cheers Anth.
Jas 👍
