Friday Brake Porn! RB Racing Discs
Posted: Fri Mar 22, 2019 3:06 pm
by Toffeebananas
Finally got round to fitting the new brakes! Bells and Rotors, cross drilled. Larger 410 discs on the front using spacers on the calipers. Brembo Pads all round.
Big thanks, to Jamie at RB Racing for supply of the discs 😉, MikeFish for sorting me a good deal 😉, and LeeRS6 for pointing me in the right direction for some good priced front Brembo pads 😉
Still bedding the discs and pads in so can’t comment on performance.
Fitting of discs and pads was all straight forward, and no Vagcom was needed. (Unbolted the rear handbrake motors to do the rears). :thumbs:
Re: Friday Brake Porn! RB Racing Discs
Posted: Fri Mar 22, 2019 3:14 pm
by LeeRS6
They certainly look the part, will be very interested to see if there's much difference in performance.
Posted: Fri Mar 22, 2019 5:19 pm
by uplandsway
Toffeebananas wrote:Finally got round to fitting the new brakes! Bells and Rotors, cross drilled. Larger 410 discs on the front using spacers on the calipers. Brembo Pads all round.
Big thanks, to Jamie at RB Racing for supply of the discs Image, MikeFish for sorting me a good deal Image, and LeeRS6 for pointing me in the right direction for some good priced front Brembo pads Image
Looks nice but Pirelli’s Image
Posted: Fri Mar 22, 2019 6:54 pm
by Toffeebananas
Pirelli’s!!!!!! I know! :shock: I read loads of poor feedback, and I even had the inside blow out on my old Pirelli’s! But I still bought another set! :biggrin2:
I like the sidewall profile!!!!! Shocking I know! But saying that, I can’t really put the performance of these down. Running 680BHP and they grip! Yes if it’s wet or damp they don’t grip too good then, but surely what does?
I haven’t tried the Mitchelins everyone raves about. May be I be tempted on the next time 😕
Got to admit the side wall is pretty though!!!??? :D
Posted: Mon May 27, 2019 7:05 am
by uplandsway
Hi matey,
How are you getting on with this set up?, more interested in the discs to be fair as will be going pagid or ferodo for pads as the OE Stuff even Brembo doesn’t cut it for me...
Posted: Tue May 28, 2019 3:39 pm
by MikeBirt
That is impressive. Interested to see what the durability and resistance to warp is, wonder if there is any play in the calliper under full braking with the spacers.
Are we allowed to ask how expensive?
Posted: Tue May 28, 2019 7:44 pm
by MikeFish
MikeBirt wrote: ↑
https://www.ebay.co.uk/itm/Audi-RS6-C7- ... 23b9c33d9e
Posted: Thu May 30, 2019 10:25 am
by bam_bam
Why are there spacers on the calipers?
Posted: Thu May 30, 2019 10:57 am
by MikeFish
bam_bam wrote: ↑
These discs are 20mm bigger than OEM (410mm) so spacers are needed to move the caliper into the right position.
by MikeFish
More of an adapter bracket than a spacer.
Posted: Thu May 30, 2019 11:19 am
by bam_bam
Ah, got it. So not a whole new bracket?
Posted: Thu May 30, 2019 12:12 pm
by MikeFish
No I don't think so. Seem to recall just a small adapter. Can't find a photo of it now.
Posted: Sun Jun 16, 2019 11:00 am
by welwynnick
I think you just use long calliper mounting bolts plus the spacers to move the callipers.
The spacers probably aren't exactly 10mm because of the geometry.
It's a mod I did on another car. It took a bit of iteration, but it turned out to be very effective.
You can only do it this way, using spacers instead of brackets, if the calliper mounting bolts are longitudinal rather than transverse. The vast majority are transverse.
Nick
Posted: Thu Oct 17, 2019 3:30 pm
by uplandsway
Toffeebananas wrote: ↑
How is your brake set holding up as interested to hear your thoughts on the bigger brake set up
cheers!
