Page 1 of 2
4 Wheel alighment
Posted: Thu Feb 07, 2019 1:45 pm
by Paulm
anyone had this done and can share their settings?? still seems to be a lot of squidgy rear and torque steer issues in here. I am sure with the right setup they can both be illuminated or reduced to acceptable levels.
I will get mine done soon and share my results. no rear end issue with my car ( although RS7 it might help RS6 as well) but suffer from torque steer now its mapped. If I can collate some info from others before I get mine done I can figure out the best settings and trial them.
Re: 4 Wheel alighment
Posted: Thu Feb 07, 2019 4:21 pm
by MikeFish
I can post my RS6 results later. I had it done after lowering 40mm then had it done again when I changed to adjustable springs and lifted it a bit.
Posted: Thu Feb 07, 2019 7:22 pm
by Paulm
That would be great
Posted: Fri Feb 08, 2019 1:31 am
by MikeFish
I could only find the original one that I had done after lowering 40mm. From memory, when I went back after raising it, they made very little changes.
Posted: Fri Feb 08, 2019 12:35 pm
by Paulm
that's great thanks.
interesting re the front geometry. Did you feel the difference on steering response pre and post? pre steering should have felt quick and a bit unsteady when cruising compared to post, steering should feel slower but less inputs to keep straight?
depending on my current setup (prob a good chunk of toe out) I intend going toe- in on the front to increase straight line stability and reduce torque steer.
I know you don't have torque steer, not sure if that's due to your suspension or the fact you are still stock? prob the better suspension?
Posted: Fri Feb 15, 2019 3:25 pm
by rs6hez
I've had mine done twice recently in the las 10 months. Both on hunter machines. 1st time was general mot station 2nd time I used My engineer who works on my GT4s as car did not feel right at the back. A lot better now. Will try and get print outs later when Im back home
Posted: Fri Feb 15, 2019 3:34 pm
by MikeFish
Sorry, I read this on the train originally and forgot to respond.
There was a huge difference (for the better) in steering and how the car turned. The car felt smaller and lighter than before. The car was only a few weeks old at the time so not sure if it was just the alignment or the combination of lowering and alignment.
Posted: Fri Feb 15, 2019 9:12 pm
by Daveperc
Here's my recent check for comparison
Car was much more balanced and agile, with substantially less wandering under power and across camber changes as a result.
Due another check in the next few weeks. :FIREdevil:
Posted: Sat Feb 16, 2019 12:53 am
by Paulm
Looks like this thread is gaining traction😂
Dave, did you forget to attach your pic? Maybe I just can’t see it as I am on phone only at the moment?
Posted: Sat Feb 16, 2019 9:57 am
by Daveperc
:oops:
Sorry forgot to "share" on Google - should be there now!
Posted: Mon Feb 18, 2019 4:15 pm
by Afsimba
Just had mine done at revolution Gateshead after new tyres can’t recomend Glenn and the lads enough although I stay in central Scotland these guys have done bits n pieces on my cars for years and very professional evert time no complaints ! They’re genuine enthusiasts and re aligned my milltek to stop it hitting transmission tunnel was not installed by them
Posted: Mon Feb 25, 2019 11:11 am
by Paulm
:oops:
sorry for late reply, just back off hols. No still cant see it :lol: All I see is a big No entry sign where the pic should be.
Posted: Mon Feb 25, 2019 1:01 pm
by MikeFish
I could see it before but now I can only see the no entry sign.
Posted: Mon Feb 25, 2019 6:53 pm
by uplandsway
That’s my most recent if it helps
Was on 21” PE wheels with Dunlop winter tyres and KW HAS
Posted: Mon Feb 25, 2019 8:02 pm
by MikeFish
How is your front camber correct with it lowered?
