Page 1 of 2
Banging/knocking when going over bumps
Posted: Tue Feb 05, 2019 10:42 am
by LeeRS6
Over the last couple of days I have had a banging coming from the nearside rear when I go over a bump, it's slowly getting worse, I've booked the car in with Audi but they can't see the car for a couple of weeks, I put the car on a jack and had a look but can't see anything obvious, reading on here I see that the DRC can fail giving a knocking sound so I'm thinking it may be this.
Has anyone had this and is it a problem if I still drive the car sensibly.
I may just drive down to Audi service and ask them to look but worried they might say I can't use the car until they can get it in which buggers me for transport.
Re: Banging/knocking when going over bumps
Posted: Tue Feb 05, 2019 12:37 pm
by Daveperc
Is the problem worse when cold than later in a journey? If so, it's a likely sign of DRC failure. The other telltale is visible "misting" of oil on the unit.
If not - have you checked for something loose in the boot well?
Dave
Posted: Tue Feb 05, 2019 1:15 pm
by LeeRS6
Its pretty consistent, I will have another look for oil etc.
Yes emptied the boot first of all, found I had a jack that I never knew I had
Posted: Tue Feb 05, 2019 2:33 pm
by LeeRS6
In Audi ATM master tech said very common and they do loads which is worrying, needs all DRC to be replaced
Posted: Tue Feb 05, 2019 3:34 pm
by MikeFish
Check the offside front too as they are diagonally connected and when leaking the noise often comes from its connected counterpart.
Posted: Tue Feb 05, 2019 3:44 pm
by LeeRS6
Both fronts have gone causing low pressure in rears and knocking, the only problem is shocks on back order, they replace all 4
Posted: Tue Feb 05, 2019 4:43 pm
by RS6chris!
Not many C6 or C7 fail to be fair!
Posted: Tue Feb 05, 2019 4:45 pm
by LeeRS6
Master tech said he had done about 40 sets but not just C7's
Posted: Tue Feb 05, 2019 4:46 pm
by LeeRS6
Something else to point out, they want the original wheels fitted to the car to submit the claim to Audi !
Posted: Sat Mar 02, 2019 11:27 am
by LeeRS6
Just thought I’d post a update, got car back from dealer yesterday, complete DRC system replaced under warranty including pipe work, all seems good and rides like new
Posted: Sat Mar 02, 2019 12:08 pm
by innercry666
Sounds like a good result! If you don't mind me asking how old is your's and has it done many miles?
Posted: Sat Mar 02, 2019 12:19 pm
by LeeRS6
Yes as it’s extended Warranty as car just turned 3 years old, 49000miles
Posted: Sat Mar 02, 2019 1:59 pm
by Weiß-sechs
Shocking that Audi are STILL having trouble with DRC after all these years
Good outcome though, congrats.
Posted: Sun Mar 03, 2019 4:43 am
by chunky79
Weiß-sechs wrote: ↑Sat Mar 02, 2019 1:59 pm
Agreed, how have they not designed it better yet? They've known for it least 13 years that it's crap.
Posted: Mon Mar 04, 2019 8:20 pm
by 2Brains
LeeRS6 wrote: ↑Sat Mar 02, 2019 11:27 am
Just got my car in at Audi now and they’ve said they have to replace shocks, I also have DRC system but I think they said they were just replacing the opposite number - so 2 in total. Any idea if this is a thing or is it normally all 4?
