Mirror Glass - NOW FIXED
Posted: Thu Jan 24, 2019 10:34 am
by ab54666
My drivers side doesn't heat, and it's annoying!
Anyone replaced theirs with a glass other than from Audi at silly prices? If so where from?
cheers
Re: Mirror Glass - where from
Posted: Thu Jan 24, 2019 11:33 am
by ab54666
In case anyone else has this issue I thought i'dd take the mirror out and have a look.
Surprisingly taking it out was very easy with my plastic trim removal tools.
On doing so all looked fine but the two wire connectors looked a little corroded, so with a little bit of fine sand paper I cleaned them up as best I could and low and behold I now have a heated mirror.... happy days, when the weathers better i'll clean the connectors a bit better.
For once an easy job.
Re: Mirror Glass - NOW FIXED
Posted: Thu Jan 24, 2019 4:16 pm
by mdrs4_82
My drivers side mirror glass is currently being replaced at the dealers. Passenger one works fine!
Posted: Thu Jan 24, 2019 4:32 pm
by Ian_C
ab54666 wrote: ↑Thu Jan 24, 2019 11:33 am
....the two wire connectors looked a little corroded, so with a little bit of fine sand paper I cleaned them up as best I could and low and behold I now have a heated mirror.... happy days, when the weathers better i'll clean the connectors a bit better.
Tiny dab of copper grease.
Posted: Thu Jan 24, 2019 8:51 pm
by ab54666
Ian_C wrote: ↑Thu Jan 24, 2019 4:32 pm
Thanks, i've got a tub so next time i flip it out will do.
Posted: Sun Jan 27, 2019 10:40 pm
by christianb7
ab54666 wrote:In case anyone else has this issue I thought i'dd take the mirror out and have a look.
Thanks for this update and great you got it fixed. I am hoping I have the same problem with mine. For removal is it just a case of prying it out from the outer side of the mirror? I imagine there are 2 or 3 clips holding it in place?
Posted: Mon Mar 11, 2019 10:26 pm
by ab54666
Sorry, only just seen this so a bit late - I used the plastic tools you get for removing car trim, yes, just pry out.
Posted: Tue Mar 12, 2019 12:24 am
by MikeFish
Cheap little suction pads from amazon, like the ones they use when replacing windscreens work well too.
Posted: Wed Mar 20, 2019 9:31 am
by christianb7
Thanks both. I did manage to get the mirror out, small suction cup and some string to help pull from the back. Although, cleaning the contacts as best I could didn’t do anything, then a little copper grease allowed it to operate for one heat cycle but has now stopped again
Maybe time for a small warranty test..
