Page 1 of 2
Front centre speak vibration.
Posted: Sun Jan 06, 2019 8:13 pm
by RSVI
Anyone else suffer(ed) with the front centre speaker, on the dash below windscreen distorting/vibration when music up loud?
Taken apart but not really studied properly yet... still vibrating when playing high volume music.
TIA
Re: Front centre speak vibration.
Posted: Sun Jan 06, 2019 8:25 pm
by doodlebug
Yes...standard A6 build. It wasn’t sorted at the factory until sometime after 2015 facelift. Take it to dealer they’ll sort on warranty.
Posted: Sun Jan 06, 2019 8:41 pm
by RSVI
Thanks Doodle
Posted: Sun Jan 06, 2019 9:04 pm
by MikeFish
Or just disconnect it and enjoy the huge improvement in sound and stereo imagery.
Posted: Sun Jan 06, 2019 10:51 pm
by RSVI
MikeFish wrote:Or just disconnect it and enjoy the huge improvement in sound and stereo imagery.
Seriously?... or you pulling my leg?
Posted: Sun Jan 06, 2019 11:33 pm
by MikeFish
Serious. I couldn't stand how all the focus was in the centre and distracted from the stereo imagery. And it is an awful speaker. So I disconnected and it sounds so much better now. Not sure why they thought stereo music should be mainly coming from a centre channel!?! I understand if watching a DVD you'd want the focus to be the centre channel for dialogue but not when listening to music.
Posted: Mon Jan 07, 2019 9:47 pm
by RSVI
Cheers, I’ll give it a go
Posted: Mon Feb 18, 2019 6:13 pm
by RSVI
Update- I didn’t disconnect the speaker, but instead removed the cover/grill, then laid it back in place without pushing in to enable the clips.
It’s slightly raised now, so not as flush, but the vibration has gone without loosing a speaker.
Happy
Posted: Thu Feb 21, 2019 3:56 pm
by dannyuk
Does anyone have any ideas on how to disconnect the speaker? Can we just pull a fuse, or do you need to take the unit out?
Posted: Thu Feb 21, 2019 6:18 pm
by MikeFish
dannya32 wrote: ↑Thu Feb 21, 2019 3:56 pm
Speakers don't have fuses. Just unplug the speaker itself.
Posted: Fri Feb 22, 2019 8:41 pm
by dannyuk
MikeFish wrote: ↑Thu Feb 21, 2019 6:18 pm
Cheers, I will give it a go, our of interest can you just remove the trim bit around it and pull it out?
Posted: Fri Feb 22, 2019 8:59 pm
by MikeFish
dannya32 wrote: ↑Fri Feb 22, 2019 8:41 pm
The trim is just held in with plastic clips. If you have any trim removal tools take the thinnest one and wedge it into the edge closest to you and lift the trim out. If you don't have trim removal tools then maybe something like a screwdriver with a rag over the end to protect the dash will do.
Once the trim is off, the speaker is held down with 2 screws (either tor or allen key, can't remember). As the isn't much height due to the windscreen I used a little socket set with the right bit to loosen it then just twisted the bit with my fingers to completely remove the screws. Probably takes longer to type this all up and read it then actually do it.
Posted: Fri Feb 22, 2019 11:28 pm
by dannyuk
Cheers Mike - I'll give it a go tomorrow
Posted: Mon Feb 25, 2019 12:42 pm
by RSVI
dannya32 wrote:MikeFish wrote: ↑Thu Feb 21, 2019 6:18 pm
Trusty dinner knife worked for me, but don’t tell the wifey
Posted: Thu Jun 27, 2019 9:33 am
by ab54666
Anyone replaced the speaker, any idea on size? Or Is the vibration the grill?
