Replacing tyres - In pairs or single tyre if other side is 6.5mm
Posted: Sun Nov 11, 2018 10:09 am
by chandler99
Hi All,
thanks to a lovely pot hole (remind me again why we pay road tax) i've got a slash in the front left tyre wall. Both fronts are on 6.5mm so there question is, replace a single tyre or will it need both? Luckily, the alloy looks totally untouched, well visually anyways
cheers for any advice guys
Re: Replacing tyres - In pairs or single tyre if other side is 6.5mm
Posted: Sun Nov 11, 2018 11:12 am
by RS6chris!
Think you be ok
Could always go nearly new on eBay? Some good tyres with nothing wrong with them...all brands and depths?...one with similar tread wear?
Posted: Sun Nov 11, 2018 12:10 pm
by Daveperc
I'd replace both fronts, but keep the good one as a spare if you have another puncture.
Posted: Sun Nov 11, 2018 12:18 pm
by Markwes
As Chris said above, get a part worn tyre off eBay, 6-6.5mm, run it until both fronts are worn then replace with new.
I’ve had loads of part worn tyres off eBay before and never had a problem.
Posted: Sun Nov 11, 2018 1:35 pm
by Daveperc
Personally I don't trust second hand p/w tyres. You have no way of knowing their history and whether there is any hidden damage to the carcass. For the one component that sit's between me (+ passengers and car) and an accident I want to know it's in great shape!
If you do go down the part worn route, at least do yourself a favour and put it on the rear.
Posted: Wed Nov 14, 2018 6:58 pm
by Anth
Same thing happened to me. Very annoying, trouble is you risk winding up the front diff I guess when I spoke to the Audi senior tech . But chances are low .
Posted: Wed Nov 14, 2018 9:52 pm
by Markwes
Anth wrote:Same thing happened to me. Very annoying, trouble is you risk winding up the front diff I guess when I spoke to the Audi senior tech . But chances are low .
I’ve read that the tolerances stated by Audi are 3/32” on the rolling radius of all 4 tyres. So basically as long as your tyres are with in roughly 2mm of each other it’s not an issue and as the OP states, his tyres are on 6.5mm. Putting one new tyre on which will have 8mm tread would be fine.
Posted: Tue Nov 20, 2018 10:21 pm
by Anth
Markwes wrote: ↑Wed Nov 14, 2018 9:52 pm
Audi says a maxium of 2mm difference on same axe to prevent problems . Side wall damage is a pain in the arse for sure .
