Brake Pedal Drop?
Brake Pedal Drop?
Evening Gents,
Just back from being away with work for 2 weeks.
Picked up the motor and drove over 100 miles home.
However, on the way back I was pressing on the brakes (and successfully braking) before the pedal seemed to drop maybe an inch before coming up to pressure again and apply the brakes. Seemed to happen twice.
I’ve done some testing by braking slowly as well as some rapid hard braking and it all seemed fine.
Anyone got any ideas as to what could be the issue?
Appreciate any input - thanks.
Edinburgh Based Nardo Grey C7 RS6
Re: Brake Pedal Drop?
Maybe air? Although if it's not happened again think your good, take it in if its under warranty and get them to flush it from the calipers if you think it's not right . If it's not covered it's about £120 All in .
2017 C7 RS6 PE Nardo
2014 911 991 C4S PDK White
2013 M6 Cab Blk
2012 911 997 MK2 PDK Silver
2007 RS4 Cab Grey
2013 M6 Cab Blk
2007 RS4 Cab Grey
Someone on here once had a discussion with one of the design engineers and they said the car had a means of controlling brake pedal travel and will adjust itself if it thinks there is too much pedal travel. Could have just been the car adjusting itself.
Not sure if its the same issue but twice I've had an issue on the motorway where I have applied the brake and the pedal dropped about an inch and applied heavy break to the pads before coming back up. Quite unnerving when you don't expect it.
Was it raining as I understand that the brake pads occasionally squeeze the disks to clean them when you are driving in the wet.2Brains wrote: ↑Wed Nov 07, 2018 7:59 pmEvening Gents,
I had a similar problem twice about three months apart... I'd press the brake and it did not feel normal. In fact it felt like when you press it and the ignition is off. Quite unnerving when on the motorway. Dealer couldn't find anything wrong and fortunately it hasn't happened since.
Current: 2019 BMW Alpina - B5 Bi Turbo Touring
Current: 2014 Land Rover Defender 110 All Black
Previous: 2017 RS6 Performance - Misano Red with Black Styling Pack
Previous: 2014 RS6 - Misano Red
Previous: 2004 S4 Avant - Nogaro Blue
Previous: 2001 S3 Absolute Red
Thanks gents - as always much appreciated.
Yes, it was raining both times!
Hasn’t happened since but will keep an eye out for it and if it happens again - get it in under warranty.
Very unnerving! Makes you lose a bit of confidence!
I had exactly the same last Sunday, road was wet, I was already lightly braking when the pedal dropped an inch, my instinct was lift off and reapply, so it all happened within a few seconds, and pedal was normal again and has remained normal ever since? Very strange experience in such a heavy fast car... i'd like to know my brakes will be working properly 100% of the time thanks
That’s absolutely what I experienced.Yossarian wrote: ↑Thu Nov 08, 2018 2:25 pmI had exactly the same last Sunday, road was wet, I was already lightly braking when the pedal dropped an inch, my instinct was lift off and reapply, so it all happened within a few seconds, and pedal was normal again and has remained normal ever since? Very strange experience in such a heavy fast car... i'd like to know my brakes will be working properly 100% of the time thanks
I’ll speak to audi - see if they can shed any light!
I had the same when in very heavy rain last year.
I’m reluctant to put it down to the discs getting gemtly squeezed to keep them dry as I thought that happened imperceptibly and constantly as you drove when the windscreen wipers on.
So not sure what it was.
Panamera ST Turbo, RS6 (C7), Cayenne Turbo S (958), RS4 (B8), ML63 (2010), 997.1 TT, 997 4S, ML63 (2008), CL55, CLK320, Toyota Corolla GTi 16v, Honda CRX, Passat V6
Maybe it is part of the driver alertness monitoring? Not satisfied that a "rest recomendation" alert on the dash made any difference, some development engineer decided that the best way to ensure the driver stayed alert is to randomly scare them shitless.
Glyn
Navarra Blue RS6 Vorsprung (C8)
Sepang Blue RS6 Performance (C7) - sold
Sepang Blue S5 sportback (B8.5)- sold
Monza Silver RS6 (C6) - sold
Sprint Blue RS4 (B7) - sold
Polar Silver RS2 (B4) - sold
You know you can turn the 2 hour warning off?
But the brake pedal is more likely to do with the automatic braking systems like active brake guard etc.
Has happened on both my 6's - last time being Tuesday - go to brake gently, having not touched the brakes for a good few miles, then pedal drops what feels like a long way and the brakes are applied rather hard!! - There was a discussion on this a while back - would appear to be normal, but disconcerting at best. Not least when your other half thinks you are slamming on the anchors for no reason!
2018 Brabus G63 Widestar
2015 RS6 - with Added Milltek
2015 RRS - utter sh1te
2010 X5 4.0D M Sport
2009 R8 V10 Manual
2004 Lambo Gallarado Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
1990 Dimma Cosworth H20 COS
2003 996 DMS Turbo
multiple 205's Dimmas
2009 R8 V10 Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
2003 996 DMS Turbo
I can't comment on the Rs6 because I don't have one.....yet!
However I have had this problem on my m5 and it turned out to be the brake cylinder which had failed
I opened a thread about this awhile ago, as experienced the exact same symptoms. Went to press brake pedal (gently) and it sunk down but the breaks were applied really hard!
I was thinking that i might have triggered an emergency brake response by the speed my foot switched from accelerator to brake (ie very quickly); and although I didn’t hit the brake hard, maybe it thought I was making an emergency reaction.
It’s only happen to me twice in a year and a half of ownership.
2016 C7 RS6 - Panther Black
Previous:
2008 B7 RS4 Avant, Phantom Black
Previous:
Exactly the same as I experienced, happened around 4 times with me; once when I was coming up on stationary traffic a bit too quick, the other times, just pressing it gently in normal driving.bn8959 wrote: ↑Fri Nov 09, 2018 10:55 amI opened a thread about this awhile ago, as experienced the exact same symptoms. Went to press brake pedal (gently) and it sunk down but the breaks were applied really hard!
I don't have ACC etc.
2009 R8 V10 Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
2003 996 DMS Turbo
2009 R8 V10 Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
2003 996 DMS Turbo
Users browsing this forum: Google [Bot] and 76 guests
