Parking heater (UK)
Posted: Sun Sep 09, 2018 8:27 am
by HDPete
Has anyone installed an aftermarket parking heater in their RS? Winter is approaching and I leave rather early and it would be kinder to the neighbours if my car was defrosted prior to my departure without the engine running for too long :)
Any links to a suitable product?
Re: Parking heater (UK)
Posted: Mon Sep 10, 2018 9:17 am
by aerospace100
Looking at the Audi website it appears the auxiliary heater is available for Q2 and A3 models only. However, further searching on Google suggests it could be done from 12V supply on a timer - unofficial part.
https://shops.audi.com/en_GB/web/zubeho ... ary-heater
Posted: Mon Sep 10, 2018 11:46 am
by LeeRS6
Kufatec do a kit but it says not Suitable for RS6
Posted: Mon Oct 08, 2018 6:44 am
by Knobby
Love this idea!
No one does an after market product that you can just chuck in the boot to heat up inside the car?
Posted: Mon Oct 08, 2018 10:21 am
by LeeRS6
Years ago I had a 12v heater in the boot, I had the car reversed up to the garage with a power supply on a timer in the garage, it worked like a dream :D
Posted: Mon Oct 08, 2018 12:44 pm
by MikeFish
Did you ever drive off before remembering to disconnect it?
Posted: Mon Oct 08, 2018 1:21 pm
by bam_bam
Over at the OP's house...
Posted: Mon Oct 08, 2018 1:41 pm
by LeeRS6
Yes, quite a few times :D but I planned for that and the connector easily pulled apart.
Posted: Mon Oct 08, 2018 1:58 pm
by Daveperc
If it's just a 12v fan heater you want then there are loads about. See https://www.carparts4less.co.uk/cp4l/p/ ... eIEALw_wcB for eample.
But if you are going to have to plug in an external charger, why not just buy a mains fan heater and plug that in??
Posted: Mon Oct 08, 2018 2:18 pm
by LeeRS6
I didn't want to have a 240v lead and plug outside, the 12v didn't matter if it got wet or damp.
Posted: Mon Oct 08, 2018 3:03 pm
by Daveperc
You can keep both ends of an extension lead dry by simply keeping the socket inside the car, and the plug in the garage. Then all you have is a cable outside.
Plug in electrical heaters (mains) are common in Scandinavia, as are block heaters etc - all mains powered.
Of course, it does slightly up the ante if you drive off without unplugging! :oops:
