Ispiriwheels
Posted: Fri Mar 16, 2018 12:34 pm
by jipettersen
Has anyone tried products from this company?
ispiriwheels.com
Re: Ispiriwheels
Posted: Fri Mar 16, 2018 12:56 pm
by MrHilario
A simple search of the forum will bring up hundreds of results.
Re: Ispiriwheels
Posted: Fri Mar 16, 2018 1:02 pm
by morski
I nearly bought a set but tbh found there service a bit pants. they would not commit to giving me the correct offset needed for my car and said 10" wide would fit.( have the bitdi) and if they didnt it would be my responsibility and cost to send them back.
If you already know the width and offset you need then should be fine.
Which design are you looking at?
Re: Ispiriwheels
Posted: Fri Mar 16, 2018 9:46 pm
by RS6chris!
Yep had two sets
No problems
Re: Ispiriwheels
Posted: Fri Mar 16, 2018 10:49 pm
by jipettersen
I have already got the FFR1 in Titanium from them. 21x 10,5 ET30. Havent try them on the car yet as i put 285/30 rubber on them next week. But seems to get close to suspension. Goes in 17mm and out 5mm vs OEM. Negative scrub radius is then about -5 mm. Want to go for 5mm spacers all around. Should be Ok?
Re: Ispiriwheels
Posted: Fri Mar 16, 2018 11:49 pm
by MikeFish
I know plenty of people that have these wheels with no issues.
Re: Ispiriwheels
Posted: Mon Mar 19, 2018 7:09 am
by Cook
No issues thus far. Just purchased wheel spacers to bring out a little though to help with placing under the arch better.
Re: Ispiriwheels
Posted: Mon Mar 19, 2018 1:56 pm
by jipettersen
Tried them on with OEM rubber . They are very close to suspension without spacers. We are talking about 2-3 mm/ 0,1 " . Will install 5mm spacers then i can use the same wheel bolts and also improve looks.
I see some of you with 10,5x21 has 15mm/20mm spacers. Is that with 10,5 ET 30?
Re: Ispiriwheels
Posted: Mon Mar 19, 2018 8:24 pm
by RS6chris!
Two pics
First and second C7
20mm rear Spacers
15mm front Spacers
25mm drop
Re: Ispiriwheels
Posted: Mon Mar 19, 2018 10:15 pm
by jipettersen
Perfect look :-)
Is this 10,5" wheel with ET30 and you still go with 15/20 mm spacers?
Re: Ispiriwheels
Posted: Tue Mar 20, 2018 4:07 am
by becausephilchow
No way those are ET30 with 15/20MM Spacers...must've been a higher offset wheel.
That would make it 10.5 +15 Front and +10 Rear. That's very aggressive.
Re: Ispiriwheels
Posted: Tue Mar 20, 2018 8:24 pm
by RS6chris!
Yes they are.
I’ve ran numerous different set ups.
Re: Ispiriwheels
Posted: Tue Mar 20, 2018 8:31 pm
by RS6chris!
Couple more
