Tyre pressures
Posted: Thu Jan 25, 2018 12:12 pm
by techyreg
Have C7 RS6 wheels with Dunlop winter tyres 285 30 21 fitted to my RS7.
Can anyone tell me recommended tyre pressures displayed on RS6.
Ta!
Re: Tyre pressures
Posted: Thu Jan 25, 2018 12:30 pm
by harrier
Hope this helps:-
Re: Tyre pressures
Posted: Thu Jan 25, 2018 2:02 pm
by MikeFish
Mine are different to that
Sent from my SM-G935F using Tapatalk
Re: Tyre pressures
Posted: Thu Jan 25, 2018 3:37 pm
by Scotty C
techyreg wrote: βThu Jan 25, 2018 12:12 pm
Ta!
I am currently running my Dunlop Winters at 44 in the front and 42 in the back. Seems to work ok for me.
Re: Tyre pressures
Posted: Thu Aug 23, 2018 10:56 pm
by Anth
Bumping this, had a a nightmare yesterday and damaged my 285/30/21 contact 5P on a brick sticking out of some uneven ground ! Don't ask .
Anyway replaced fronts as was down to 4m anyway and got 42 front 40 rear . Was thinking u should be 38/35 maybe what are people running ?
Re: Tyre pressures
Posted: Fri Aug 24, 2018 12:12 am
by MikeFish
I run 2 psi below what my
Sticker says so 39 front and 36 rear.
Re: Tyre pressures
Posted: Fri Aug 24, 2018 4:54 pm
by chandler99
MikeFish wrote: βFri Aug 24, 2018 12:12 am
Interesting, whats the reason for that if you don't mind me asking?
Re: Tyre pressures
Posted: Fri Aug 24, 2018 8:57 pm
by MikeFish
It just feels better for me a bit lower than recommended. I ways run my audis a bit lower than the factory figures.
Re: Tyre pressures
Posted: Fri Aug 24, 2018 9:28 pm
by skirs6
Re: Tyre pressures
Posted: Fri Aug 24, 2018 10:13 pm
by MikeFish
Haha must be leaking a bit Mr Audi, was at normal psi last time I checked.
Re: Tyre pressures
by MikeFish
With my non audi approved Michelin.
Re: Tyre pressures
Posted: Sun Aug 26, 2018 7:06 pm
by Anth
Is there anyway to callabrate the software received from the sensor, I have 40 recorded on my two other devises and the car always is 2psi above?
Re: Tyre pressures
Posted: Sun Sep 22, 2019 6:24 pm
by Treg
Mine are at Front 41 and rear 38.
Same tyres as the op.
Does that sound ok?
Re: Tyre pressures
Posted: Sun Sep 22, 2019 6:42 pm
by Scotty C
I run my winters on 42 at the front and 39 at the rear with an average load...
Re: Tyre pressures
Posted: Thu Sep 26, 2019 9:09 am
by Treg
Just looking at the guide plate on my 2014 car it recommends 39 psi front and 35 psi rear with 285/30/21 tyres so I'm going to try that.
