Start/stop issue
Start/stop issue
On a few occasions now when car has switched off via the start/stop - when it has come to restart it has not started cleanly. Couple of times it fired over a few times like as if the battery was low (it isn’t) and other times it hesitates.
Anyone suffered this? I reported to the stealers when it was last in for its brakes but they couldn’t find any faults etc.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
Re: Start/stop issue
Best thing switch it off when you first get into the car
Star stop is a waste of time imo it must do excessive waer to the starter motor
And the small fraction of fuel and CO2 it saves is a PR excersise fof the manufacturer
There must be a way to either disable it completely or get it to remember its last settin
I did that in my wifes SQ5 as she found the stop star a pain too
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Do you have auto handbrake on? If so, try turning it off to see if you get crisper re-starts.
Not sure if it was engaged will check for next time however, could it be a factor to possibly cause that issue though?Markp wrote:Do you have auto handbrake on? If so, try turning it off to see if you get crisper re-starts.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
You can make it remember the last setting or turn it off completely using VCDS.Brooner wrote: ↑Sat Dec 16, 2017 5:13 amBest thing switch it off when you first get into the car
Thats the answer for me then mike if only i could find the coding for the 2017 S3 to do the same
I find it comforting when sat in London traffic and it’s switched off unlike the C6 which used to taunt me with its 6mpg figure when sat in traffic
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
Turn it off (including COD altough the last needs to be done by tuner).
I can understand if your daily route has often traffic jams it might be worth it, but as noted (altough not sure) it wears starter afaik.
Same for the COD, again not sure, but more affraid of the long term wear and uneven wear of the constant working cyllinders versus the shutdown cylinders (cylinder wear, spark/coil plug/injection etc...). Soon will completly write out COD (mostly because of the noticable change when COD kicks in/out since i'm aftermarket exhaust/DP). Not sure if gasmilage will change much (only -50% of my daily route it uses COD)....sorry nature/gasmoney wallet, but full V8 for me please
No tried it on the Audi but on our new Golf the auto handbrake alters the stop start in that the car often doesn't fire up the second you start to lift off the brake - indeed it often only starts when you touch the throttle.
Was it the voltage change that was mentioned thd first time 8 posted thd request
Haven't had s chance to try that one yet
But would prefer the remember tge last setting option
Yes I changed the voltage. Think I had to use a different voltage as the quoted one didn't work for me.
I haven't found a setting to retain last used mode yet.
Can you remember the voltage setting you used
Users browsing this forum: No registered users and 114 guests
