Page 1 of 2
Milltek help
Posted: Sun Jun 04, 2017 9:22 am
by J66kco
Had milltek cat back fitted yesterday and although i love the sound the exhaust is producing, there is a knocking when on bumpy roads. I have today jacked car up and can see the front section (mesh type part) on drivers side is virtually touching the bottom corner of the gearbox. The flange is bolted perfectly aligned to the cat, so can't see how it can be adjusted. Has anyone else seen this or got a picture of where front section joins cat from under car when there's was fitted?
Re: Milltek help
Posted: Sun Jun 04, 2017 1:58 pm
by dasquade
100% sure it is that part that is causing the knocking?
I suppose in your case it is that, but for what it is worth...altough S6 avant here....on mine the problem was on the rear. The left exhaust pipe almost touches one of the side cross brace in the last section of exhaust. Never know it is also that...or combo.
If not, not sure how your issue can be fixed.
Re: Milltek help
Posted: Wed Jun 07, 2017 2:16 pm
by J66kco
dasquade wrote: ↑Sun Jun 04, 2017 1:58 pm
Front section as been manufactured wrong, flange welded at wrong angel resulting in the pipe touching gear box.
Re: Milltek help
Posted: Wed Jun 07, 2017 5:24 pm
by RS6chris!
I had a slight knock with my milltek
Tight right hand turns...lateral movement.
Probably shitty milltek quality control.
Re: Milltek help
Posted: Wed Jun 28, 2017 1:34 pm
by J66kco
Front section has been replaced by milltek. New section fitted to car and exactly the same issues the section sits about a 1mm away from gear box.
Contacted milltek again who said send it back and they will check it on there jig or travel 150 miles to my nearest authorised milltek fitter for them to have a look at.
I'm not happy with there response so have contacted supplier to return the full system which I'm gutted to do as I love the noise the car now makes.
Now looking at following a few on here and have front boxes removed for the sports exhaust.
Re: Milltek help
Posted: Wed Jun 28, 2017 6:32 pm
by RS6chris!
Well you know what my answer would be??
Send milly back
Get front and middle boxes took out £200 max
As near as dam it to a non res milly.
Re: Milltek help
Posted: Wed Jun 28, 2017 6:53 pm
by J66kco
RS6chris! wrote: ↑Wed Jun 28, 2017 6:32 pm
Send milly back
Milltek is going back
Only a couple of exhaust fabricators in Cumbria which I've phoned today. Neither filled me with confidence regarding removal of front and middle boxes!!
Can you recommend anywhere in north east?
Re: Milltek help
Posted: Wed Jun 28, 2017 7:04 pm
by RS6chris!
I used
Exhaust A Fix
Based in Darlington
Drove in at 1pm....all done by 3:30!
Top job
Re: Milltek help
by RS6chris!
Picture of removed boxes
Re: Milltek help
Posted: Wed Jun 28, 2017 7:05 pm
by RS6chris!
Car lighter now also as added bonus! Lol
Re: Milltek help
Posted: Wed Jun 28, 2017 7:29 pm
by J66kco
RS6chris! wrote: ↑Wed Jun 28, 2017 7:04 pm
I used
Exhausts a fix
Based in Darlington
Top job
Cheers mate, il give them a call
Re: Milltek help
Posted: Wed Jun 28, 2017 7:56 pm
by dasquade
Bit odd that both exhausts didn't fit good, wild guess, but maybe one OEM downpipe is not perfect and the issue is there instead of the milltek?
Again, wild guess.....
Re: Milltek help
Posted: Wed Jun 28, 2017 10:26 pm
by J66kco
dasquade wrote: ↑Wed Jun 28, 2017 7:56 pm
I thought the same but the OEM sports exhaust fits perfectly in the centre of the channel about 30mm off the gear box
Re: Milltek help
Posted: Wed Jun 28, 2017 10:36 pm
by J66kco
Re: Milltek help
Posted: Thu Jun 29, 2017 6:45 am
by Leo-RS
Strange one as there are obviously hundreds of cars out there running Milltek trouble free. I never had any issues with mine but admittedly I didn't check the clearance either. I doubt very much it's a design issue or Milltek would have been aware of it and redesigned it, something must be different about your particular car.
