RS6 Carbon Ceramic - Pad Knock
Posted: Mon May 22, 2017 11:29 pm
by TRS6
Hi Guys
So my 2016 RS6 has been back and forth to the dealer for warranty work as the front pad's appear to make a god awful clunk whilst parking.
It mostly occurs during change in directions from forwards to revers during low speed.
So far the dealer has advised they are ordering some brake pad adhesive to attempt to remedy the problem??
Anyone have/had similar issues? And know of solution?
Re: RS6 Carbon Ceramic - Pad Knock
Posted: Tue May 23, 2017 6:51 am
by Markp
My GT3 did this after I removed the pad dampers designed to prevent this (and rattle) - they get too hot in track use and melt. Does the RS6 use a similar system?
Posted: Wed May 24, 2017 3:31 am
by TRS6
I left it to the apparent experts at Audi Dealership on this one..
No idea if its the same or similar to the GT3 setup? I looked over my GT3 but it runs the steel brake setup and imagine those dampers are only on the PCCB?
Posted: Wed May 24, 2017 7:39 am
by Markp
TRS6 wrote: ↑Wed May 24, 2017 3:31 am
No steels have them. They are round adhesive rubber things on inboard side of pad (from memory).
Posted: Wed May 24, 2017 7:42 am
by Markp
This is the sort of thing. Typically 2-4 stuck to each pad depending on the application.
https://www.paragon-products.com/Brake- ... 086.00.htm
Posted: Fri May 26, 2017 3:43 am
by TRS6
Thanks Mark!
Dealer is looking into this one again.
Appears they said pad knock is normal and are applying just an adhesive tape to back of pads.. Doubt this will resolve anything
Keep you posted but hoping someone else on here with Ceramics may have some further insight???
