H&R ETS lowering module..
Posted: Sun May 14, 2017 8:43 pm
by Knobby
I am on Air and really like the sounds of the H&R ETS lowering module... Does anyone know if it can be fitted to a facelift car? I'm sure I read somewhere they would only go on a pre FL car, but can't find the post again.
Anyone on here got one fitted?? Its it adjustable?
Dave
Re: H&R ETS lowering module..
Posted: Wed May 17, 2017 7:32 am
by rtd
Cete Automotive and MTM also do lowering modules for AIr equipped cars.
Posted: Fri May 19, 2017 12:52 am
by dasquade
Just installed my CETE lowering module. Very happy with it
Got version 2: bluetooth and the additional 4 wheel recalibration mode.
Posted: Fri May 19, 2017 3:38 am
by rtd
Got any pics of car lowered? Is your car on air? Does your car have adaptive cruise, any issues since you've lowered car?
Posted: Fri May 19, 2017 6:15 am
by Knobby
dasquade wrote:Just installed my CETE lowering module. Very happy with it
The CETE module looks very cool. Like the idea of being able to adjust with my phone. Do you use the show mode?
Are you in the U.K? And did you fit it?
Posted: Fri May 19, 2017 6:17 am
by MikeFish
I know someone with the MTM lowering module and it looks really cool.
Posted: Fri May 19, 2017 6:41 am
by Knobby
Had a look at the MTM version. A lot more money and needs to be fitted by an approved dealer.
Posted: Fri May 19, 2017 9:35 am
by dasquade
Yes car has adaptive cruise, normally no issues (havent driven the car yet but everybody says it isn't an issue). Since you lower the car front and rear the same heihgt (normally) the car stays level but just lower. Same for the headlights leveling.
The showmode drops the car to max. 40mm but you can buy the 25€ full air vent dropping it even lower (i didn't as i don't think it is that good for the bags).
I'm from belgium, no pictures yet. Dropped the car 30mm...
Fitted it myself. It only involves pulling 3 plugs and insert the bypass module (if you have facelift you need to add wires into the canbus plug but that is easy too).
