Fuel Consumption
Posted: Fri May 05, 2017 10:54 am
by RSQ
I think mine is not too bad for the performance over it's first 4.5k miles, but then I was stuck in traffic for an hour last night, thanks A13...
Re: Fuel Consumption
Posted: Fri May 05, 2017 12:57 pm
by ics3s
For mostly highway drive is ok. I mostly drive in the city and get 15 l/100km (19mpg) w/o start stop enabled.
Posted: Fri May 05, 2017 1:20 pm
by gilford
First thing I do when I get in the car is knock the gear stick down to S and turn stop start off, day to day it averages around 18mpg but on a run 28mpg, which isn't bad for such a powerful car.
Posted: Fri May 05, 2017 1:22 pm
by stevo55
The C7 can't exactly be classed as economical but I'm massively impressed at getting 29 mpg (my record so far) on a long run. Only a former C6 RS6 owner can be impressed by that! The thirst of the old beast was biblical
Posted: Fri May 05, 2017 2:21 pm
by MikeFish
Yes it can be "economical" when on the motorway. This is when it is better than my 4. But when hooning around it is worse than the 4.
Posted: Fri May 05, 2017 2:24 pm
by MikeFish
gilford wrote: ↑Fri May 05, 2017 1:20 pm
You know you can use
VCDS to permanently turn off stop start or do as I did, make it remember last position so once I turn it off it remains off until I decide otherwise (which is never). I also have inverted the light on the button so it is off when start stop is off as being lit all the time would annoy me.
Posted: Fri May 05, 2017 2:27 pm
by RS6chris!
I couldn't care less...
But as said coming from a C6 this thing is epic!
Posted: Fri May 05, 2017 2:53 pm
by gilford
MikeFish wrote: ↑Fri May 05, 2017 2:24 pm
Thanks for the tip, but I wouldn't have a clue on how to do it!
Posted: Fri May 05, 2017 3:31 pm
by RSQ
On the same regular journeys my Astons did around 14 mpg. So to me the RS6 is like a Prius
Posted: Mon May 08, 2017 9:20 am
by Bit_evl
Recently bought an ML63 with a tweak and am seeing 16.4mpg on average. This thing is hilarious.
Posted: Mon May 08, 2017 1:49 pm
by stevo55
Well today I decided to see how far I could push it and was chuffed to see 31.2 mpg! Reckon I could get more as well, I was running on a less than 1/4 full tank and in comfort mode which seems to be the best for getting the most mpg.
Posted: Mon May 08, 2017 2:47 pm
by E14STO
Average since owning is 16mpg
Round town I'm about 11-12 and commuting and motorway 29-30
The worst average I've ever had in any car... even my TVR wasn't that bad (18)
Posted: Mon May 08, 2017 5:57 pm
by tartan_rob
IainM on here quite often gets mid-30's when his partner drives on long runs.
Posted: Tue May 09, 2017 1:22 pm
by Iain
tartan_rob wrote: ↑Mon May 08, 2017 5:57 pm
She managed Cardiff to Cambridge and back on a single tank - 75 miles left showing to empty upon return
Posted: Tue May 09, 2017 1:57 pm
by stevo55
The novelty of it all hasn't worn off yet-I find myself trying to get max mpg and the DIS is constantly on the 'mpg' scale. I know it's not what RS6 ownership is about but after the C6 -best described by Top Gear as 'like chucking buckets of unleaded down a car shaped storm drain'-it really is a breath of fresh air.
Obviously the hammer does come down often as well. Ticks so many boxes this car
