To Repair a Puncture or not?
Posted: Sun Feb 05, 2017 3:39 am
As a follow on from the earlier "Tyre advise" thread, having had one mid tread puncture on one rear tyre and now loosing 0.5Bar a week with no visible puncture on the other rear tyre, I have been keen to get a definitive answer on what I should or should not do when faced with a puncture that appears to have sealed itself. Audi has fitted the PE, mine at any-rate, with Continental ContiSport Contact 5P tyres and although the tyre with the obvious puncture seems fine now, these are ContiSilent (marked) tyres, not ContiSeal. Discovering the correct and safest course of action has become more imperative in the light of lacking or erroneous advice from all three suppliers and fitters of tyres that i have so far approached!
It took quite a bit of effort to get any contact phone number (rather than email message or "Chat") for any one at all at Continental Tyres in the UK (my German is far too rusty), but when I did get to talk to a representative they were very quick in getting a tyre technician to call me back to helpfully answer all my questions.
The answer is that if and when ContiSeal or ContiSilent tyres get penetrated causing a puncture, they BOTH have a sticky sealant layer that hopefully will seal the puncture or help to keep if from rapidly deflating. It is just that the ContSilent tyre has a thinner,less effective layer, that is chiefly there to keep the sound deadening and insulating white sponge layer in place and it doesn't cover quite as much of the tread either. When a puncture is detected, the purpose of the sealant is to enable the driver to drive the car at leisure to a garage for tyre REPAIR, hopefully without the need for a roadside repair or spare wheel. BOTH types of tyre C.-SEAL and -C.SILENT do NEED TO BE REPAIRED! The reason for this is that penetration of the tyre, by a foreign body, such as a nail, will with time allow WATER INGRESS through the cross-ply and ultimately CORROSION of the metal wires and a potentially very dangerous WEAKENING of the structure of the tyre!
I will, therefore, be getting my tyres repaired (as per Continental's online PDF Instructions), despite the (1st) tyre apparently sealing the puncture and remaining correctly inflated since then. But first the garage and I have also got to have another go at locating the site of the puncture in the 2nd tyre. This may be helped by the fact that eventually the sealant is likely to appear emerging through the perforation in the rubber, I was told.
P.S. I was also informed that tyre producers aren't, unsurprisingly, allowed in law to publish an expected mileage figure for their tyres, which one might think would be helpful, as there are always going to be far too many variables for a direct comparison with other manufacturers' products. Also, I have learned that Continental are the only company that manufacture all the parts needed to construct a car in its entirety, including naturally its tyres!
I hope this helps?
I hope this helps?
