Page 1 of 2
Enabling TV whilst driving
Posted: Sat Oct 29, 2016 12:02 pm
by rtd
Has anyone managed to do this?
Re: Enabling TV whilst driving
Posted: Sat Oct 29, 2016 12:09 pm
by MikeFish
Pre or post facelift?
by rtd
Pre mike sorry should have said 2013 car
Posted: Sat Oct 29, 2016 12:14 pm
by MikeFish
Yes it's possible with
VCDS. Do you have it or know anyone that does?
Posted: Sat Oct 29, 2016 12:15 pm
by rtd
I have it mike could you possibly advise pls?
Posted: Sat Oct 29, 2016 12:29 pm
by MikeFish
I've not tried this as it only works for pre facelift cars. In fact I think I did try it anyway but it didn't work.
Video In Motion - prevent the car from suppressing DVD playback once the speed of the car rises above 5mph
[Select]
[5F-Information Electr.]
[Advanced ID - 1A]
Make a note of the Serial Number
Go to Enable VIM TV-playback using
VCDS/VAG-COM in your Audi MMI | trick77.com
https://trick77.com/enable-vim-tv-playb ... g-com-mmi/
Follow the link for MMI 3G
Enter your serial number into the input field
Make a note of the personal login code and the alternative login code it returns
[Security Access - 16]
Enter your personal login code.
[Do it!]
If you receive a "code not valid" message try the alternative code. If neither code works it's likely that your control module doesn't support VIM adaptation.
[Adaptation - 10]
Select channel 48
Press read
Set the value from 0 to 255
Press test
Press save
Press "Done, Go Back"
Close
VCDS and reboot your MMI
To reboot the MMI (Press MENU, central MMI knob and top right softkey)
Posted: Thu Dec 01, 2016 9:42 pm
by rtd
This worked for me
Posted: Thu Dec 01, 2016 9:52 pm
by MikeFish
That'll be £80 please
Posted: Thu Dec 01, 2016 9:53 pm
by rtd
Haha no worries man - but jokes aside thanks!
Posted: Thu Dec 01, 2016 10:23 pm
by Silverfox42
Not tried this and off post, but would the same work for a '14 plate RS4?
Posted: Thu Dec 01, 2016 11:03 pm
by rtd
May not work on a FL car but seems to be ok on pre FL cars
Posted: Sun Dec 25, 2016 9:18 pm
by VAGNOSTICS
Works perfect on my 2014
Posted: Sun Dec 25, 2016 10:30 pm
by Covkiller
rtd wrote:Has anyone managed to do this?
Are you a Polish lorry driver ?
Posted: Sun Dec 25, 2016 10:31 pm
by rtd
Covkiller wrote:rtd wrote:Has anyone managed to do this?
No are you?
Posted: Sun Dec 25, 2016 10:46 pm
by Covkiller
No just having a laugh, I was in a queue into Dover and a Polish lorry driver had a 20" laptop on watching a film whilst driving.
