Intermittent Misfire
Posted: Fri Jul 15, 2016 7:17 pm
Hi all,
Bit of an issue... I have an intermittent misfire on Cylinder 5. I've changed the plug out as well as swapping coils which lead to no change. The car is a 16 plate performance edition with 6k miles.
I can't replicate the misfire regularly but it tends to happen before the car has reached operating temp and then will behave perfectly when hot and then won't miss a beat. Any ideas?
I've attached a recent VCDS readout if it helps:
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1B-Active Steering -- Status: OK 0000
22-AWD -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
30-Special Function II -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
BA-Motor Mounts -- Status: OK 0000
Address 01: Engine (------CWUC)
3 Faults Found:
13432 - Fuel Pressure Sensor (G247)
P119A 00 [096] - Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 9336 km
Date: 2016.06.23
Time: 21:18:57
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 9336 km
Date: 2016.06.23
Time: 21:18:57
10595 - Cylinder 5
P0305 00 [096] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 9336 km
Date: 2016.06.23
Time: 21:18:57
Readiness: 0000 0001
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 9336 km
Date: 2016.06.23
Time: 21:18:57
P0300 00 [096] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 9336 km
Date: 2016.06.23
Time: 21:18:57
10595 - Cylinder 5
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 9336 km
Date: 2016.06.23
Time: 21:18:57
