Page 1 of 4
DRC front shocks rattle!
Posted: Thu May 05, 2016 10:17 am
by gorun01
My 2015 fl lovely has developed an annoying rattle in the front right shock. Happens when going over minor undulations at slow speed mainly in comfort but sometimes I can hear it in auto and dynamic as well. Mind you the car has done only 12 000 kms. Took her to stealer and after a 2 hour inspection, drc pressure checks etc. they established that the other front shock rattles too. Apparently Audi are aware of the issue and are working on new front shock absorbers. I was told that the expected release date is around mid-June. :audibash:
Re: DRC front shocks rattle!
Posted: Thu May 05, 2016 10:58 am
by Markp
I have this too and hoping to get Audi to look at during first service in a month or two. Did you dealer say they would rectify it once the fix was released? Keen to avoid "they all do that sir". Sounds like something is loose at low speeds and over potholes, drain covers etc.
Please keep us posted on progress with your car.
Mark
Posted: Wed Oct 12, 2016 5:20 pm
by gorun01
Finally the shocks came and I got all 4 replaced under warranty. They do feel a little tighter but some rattle is still present at lower speeds/sharper undulations. The original shocks had got better with time to the point that the rattle had all but gone. Weird...
Posted: Wed Oct 12, 2016 5:37 pm
by Markp
Had mine done 2 weeks ago. All fixed :)
Posted: Wed Dec 07, 2016 8:34 am
by vestax32
Mark & Gorun, which dealers did you have the work done at? Want to have some back up info when my local dealer inevitably tries to tell me there's nothing wrong with the shocks!
by vestax32
Posted: Wed Dec 07, 2016 8:55 am
by zebede
It is now a known problem with a fix and a bulletin for it that the stealers will know about
Posted: Wed Dec 07, 2016 8:56 am
by zebede
Known problem that the dealer will be able to look up the bulletin for, had mine done too
Posted: Wed Dec 07, 2016 9:46 am
by RS6chris!
Can any one actually believe that we are over 15odd years since the first DRC came out and Audi STILL can't get it right????
Beggars belief to be fair.
Every generation has issues!!!
Give it up Audi FFS.
Posted: Wed Dec 07, 2016 10:29 am
by vestax32
I think it's only coming from front on my pre facelift, but is the bulletin for all 4 shocks?
Posted: Wed Dec 07, 2016 1:22 pm
by Markp
All 4 shocks get replaced
Posted: Wed Dec 07, 2016 1:28 pm
by vestax32
Markp wrote:All 4 shocks get replaced
Posted: Thu Dec 08, 2016 8:56 pm
by Daveygal
Can someone expand in this bulletin ?
Is it a mandatory replacement if shocks?
Mine is at the dealers as there was fluid showing on the front shocks. They stated it was 'misting or sweating' which i know is bollox!
Posted: Thu Dec 08, 2016 11:22 pm
by Markp
Not not mandatory. If yours rattles - typically at low speeds over uneven roads and from the front - then this is how Audi dealers are told to deal with it (after DRC check re pressure etc).
No rattle. No problem. It is normally evident from day 1 - or within a thousand miles at most. Presumably variable tolerances in some dampers. Not sure what they have changed but worked for my car.
Posted: Sat Jan 21, 2017 10:11 am
by vestax32
Mine is in having all four shocks replaced under warranty as we speak. This may sound like a silly question, but I presume they will have to remove the wheels to do this? And will have to do a 4 wheel alignment after all work completed? Or will replacing the shocks not effect the alignment?
